Mark this thread as Sold
Track forged turbo Kit & Built block
Hey guys as some of you may know my boosted project must go due to trying to get into being a home owner. I will updated this as frequently as possible right now theres mostly oem parts but will have my turbo kit, motor, ems, fuel system, shell all up for grabs once i get them off the car. Located in Queens, NY. Right now im just doing picked up or will meet you if we come to some sort of reasonable agreement. Keep in mind all turbo oriented parts are basically brand new car idled for 20 mins while boosted like i said there all basically brand new
Trackforged Turbo kit 100% complete, Precision Billet 6262, all hot parts 2200 degree coated, anodized intercooler and piping powdercoated black, downpipe, uppipe and manifold wrapped in dei heatwrap, 2 return setups included (basic kit push style fittings/upgraded hi-temp silicon hose and my 10AN braided nylon setup and fittings), 1/8bspt fitting provided so you do not need to tap oil pressure sender unit for 1/8 npt fitting which comes with the kit. The kit has 20 mins idle time on it thats it basically brand was $5K Price lowered $4.8k
Built Shortblock Darton Mid sleeves, weisco 9.5:1, manley turbo tuff rods, Custom bearing setup, has a 10an fitting welded into girdle also includes Timing chain cover, timing chain, chain guides, oil pan, basically new oil pump, guides, tensioner & chain. I straight edged the block it is straight and flat walls are in perfect shape. 3k plus shipping
10 an welded in fitting(return line not included)
cyl #4
cyl #3
cyl #2
cyl #1
BRAND NEW supertech valve guides - $80
AEM Series 2 - sold
ID 1000s- sold
AEM Boost gauge, AEM Wideband and autometer dual pod(no holes were drilled i used velcro everything in perfect condition. Still have boxes with all hardware and silver gauge faces from aem for both gauges- sold
NGK BKR8EIX run for 20 mins - sold
OEM coils sold
Prostart battery 2 months old -sold
Oem injectors - sold
Spark plug tube seals All 4 Brand new - sold
Invidia N1 single 70mm TI tip - sold
Hondata 4bar Map sensor -sold
MAC valve & T1 mounting bracket - sold
Full Blown Radiator - sold
Enkei Rpf1 Matte Black - sold
cyl #4
cyl #3
cyl #2
cyl #1
AEM Series 2 - sold
ID 1000s- sold
OEM coils sold
Sorry for the long delay guys been busy helping people rebuild houses in nj. @ cool guy there off a 00 and no it's a used oil pump with 140k still works flawless I just swapped out when I built te motor
MORE Items since they dont fit in the original post
EGR Valve, SAI pump, Solenoid & hoses -$150
OEM oil pump - sold
OEM Headbolts -$20
Tial 44mm WG flange -$10
OEM fans - driver side was modified to fit my IC piping still works 100% - $20
OEM Throttle Body - sold
OEM oil pump - sold
OEM Headbolts -$20
Nahh I'm trying to buy a house and its actually affordable now if I get rid of it, I'm pulling it all apart regardless though so I will find out what the culprit is. Right now in my life house>racecar unfortunately
-chris
You can buy a house and own a car...LoL...people do it all the time.
Seriously though, the car and all the crap is already there and paid for, all you need to do is assemble it. I've got absolutely nothing to do the next 2 Sundays...we could have her purring like a kitten in no time.
