So this is why my shifter is stuck.....
Old 11-10-2012, 11:26 AM
QuangNguyen_89616's Avatar
Default So this is why my shifter is stuck.....
SO........ a couple months ago my shifter kept getting stuck at reverse position. I ignored it, it wasn't big deal. Saw a DIY a couple weeks ago, and decided to have a look at it today. WALLLAA
What do you knowww
Old 11-10-2012, 11:35 AM
dc2-2-ap1's Avatar
Is that corrosion inside the transmission receptacle? Clean everything as well as you can and re-grease it. Use honda high temp urea grease, and don't be greedy with it.
That does look pretty disgusting.
Old 11-10-2012, 11:53 AM
I have a box of high temp grease from carquest.. would that work?
Old 11-10-2012, 12:46 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Is there dirt in there ?, it looks gritty and dirty. Corrossion often happens from water seepage from below the shifter just wondering if you are getting dirt in there as well as water seepage. If you are getting dirt in there you will need to address that issue.
Old 11-10-2012, 01:14 PM
No dirts... I have a pretty good Idea of how the water got in there too .. hehe
Old 11-10-2012, 01:16 PM
Can I use HIGH TEMP Grease from Carquest or Honda is the way to go?
Old 11-10-2012, 03:49 PM
zeroptzero's Avatar
Sure that will work.
Old 11-10-2012, 08:15 PM
darcyw's Avatar
you might also replace all the plastics as well on the shifter.
thanks for the pictures.
darcy
Old 11-11-2012, 04:10 PM
darcy
Yep. I got those (=
Old 11-11-2012, 04:11 PM
sooo... I can't sseem to put the shifter back.... I twisted and turned it a millions time.. fmll
Quick Reply: So this is why my shifter is stuck.....
