Which side of the dipstick to read?
Old 10-25-2012, 10:05 AM
sergeant dukesalot's Avatar
Default Which side of the dipstick to read?
hey guys, one side of my dipstick reads that im full on oil, while the other reads i have half, which side should i be reading? im hoping someone else has the same issue haha, its hard to describe which side is which
Old 10-25-2012, 10:10 AM
Community OrganizerMember (Premium)
jsenclosure's Avatar
there should be two holes in it...
Old 10-25-2012, 10:18 AM
ap1krod's Avatar
I think he means one side of the dipstick is full to the 2 holes, but when you flip the dipstick the other side is in the middle. Mine did that and i was just went with the side that showed full
Old 10-25-2012, 10:24 AM
Elistan's Avatar
When I check the oil, I twist the dipstick back and forth a bit when its fully seated. That little wiggle seems to do the trick of equalizing both sides.
yea its when i flip it around, it reads different
Old 10-25-2012, 10:29 AM
miguel329's Avatar
Billman on here said if one side is low add oil, pm him or look for his post, he knows his stuff on s2000's
Old 10-25-2012, 12:59 PM
apme123's Avatar
check both side, the lower masurement is the true one.
Old 10-25-2012, 01:34 PM
dwight's Avatar
search.
Old 10-25-2012, 03:48 PM
xviper's Avatar
There should never be that kind of difference between one side to the other. At most, it would 1 to 1.5 "X's" (or 1.5 diamonds), in which case, it really doesn't matter which side you take as it's not a significant difference. Either you've got the car on an uneven surface or you're doing it wrong.
Old 10-25-2012, 05:01 PM
steamedturtle's Avatar
There is almost always a discrepancy between sides when I check my oil even when on a completely flat surface. I was always taught to read from the low side.
Quick Reply: Which side of the dipstick to read?
