New Retainers, double check the TDC
Ok swapped the ap1 retainers for new ap2 retainers. 3 of 8 were cracked if you are still rocking ap1 retainers def, something to look at. Now I've read a few posts about putting the cams back in place and making sure they are aligned properly. specifically this thread
https://www.s2ki.com/s2000/topic/543...ment-question/
Now in there it says the car won't start with the cam's out of time with each other. But that is on a stock ECU. I am running an AEM Series 2 EMS so I'm not sure if that "safety feature" is part of my ecu programming. So the cams look lined up to me, they are hand tightened but not torqued to spec yet, have a look let me know if you think they are lined up. Also if you have any information on if the AEM ECU also will not let the car start with cams out of time that would be valued information. I'm just trying to be careful before putting the valve cover on and aimlessly firing the engine.
So what do you think about the alignment does it look good? I think the alignment looks good but I did this same job on my friends ap1 and the first time we tried it wouldn't start. So I'm a little worried about my eye up ability.
Since I haven't done the job myself, and I've seen some descrepancies in other peoples' pictures where the marks themselves may or may not line up perfectly, I'm hesitant to say. When I get home to my computer I'll give it a look, though.
camera is too high, and too far to the left.
Take the pic straight on. the marks will line up with the seam between the upper and lower cam towers.
crank location
doesn't look lined up by helms standarrds but head on looks good
rear cams
tdc?
any and all information appreciated
