No Brake Light or seat belt light on Dash
Old 05-07-2012, 06:31 PM
roflitzjinno's Avatar
Default No Brake Light or seat belt light on Dash
So I realized the other day that my brake light and seat belt light on my dash isn't turning on? I tried putting the top down too and now that won't go down either, I'm guessing cause the light isn't on. Anyone have an idea what it could be? I did blow the 12V socket fuse the other day. Could that have done it? No idea.
Old 05-08-2012, 12:10 AM
boyguan's Avatar
Replace the fuse and check back. Turn the ignition on but don't start the car. All the lights should come on except the brake I believe. The brake switch is at the e brake under the cover. Just a pin that might be stuck
Report back
Old 05-08-2012, 02:47 PM
I replaced the fuse 10A fuse that went out. I turned the ignition on but DID NOT start the car and the BRAKE light comes on and goes away. The seat belt light doesn't come on at all.
This brake switch is under the center console? What pin might be stuck?
Old 05-09-2012, 12:48 PM
Issue fixed.
Old 05-09-2012, 05:04 PM
spets's Avatar
AKA, how did you fix it?
Old 05-09-2012, 05:24 PM
Unplugged the brake light connection under the center console and reconnected it. Fixed the issue.
Old 05-10-2012, 06:38 AM
JohnsS2000's Avatar
if you had a fuse fail, something caused it to fail.
Mezza
11-07-2013 09:50 PM
roflitzjinno
05-10-2012 01:45 PM
_Kyo
03-07-2011 04:15 PM
FUGITIVEX
05-26-2010 09:46 AM
Random1
09-03-2005 07:51 AM
Quick Reply: No Brake Light or seat belt light on Dash
