10 Years Old - What would you replace?
UK Moderator
As my car is now 10 years old and is slowly resembling "Trigger's Broom (17 New Heads and 14 new Handles) I thought I might tap into the wisdom of the forum for suggestions as to what bits might now be a bit worn out and could do with replacing, particularly as my car gets used on trackdays.
Stuff I've had replaced outside of the service schedule:
Baffled Sump
Timing Chain and sprocket
Rear Calipers
Roof
Clutch
Cat
Respray
Coilovers
Hub nuts
Drop Link
Suspension bolts are all ok (thanks to Chris Franklin for that) so no need for suspension arms (I don't want to polybush anyway)
Stuff I'm thinking of doing:
Engine Mounts
Get drivers seat refurbished - anyone got any recommendations?
Starter motor - current one is a bit scratchy
Please add more to this list, thanks.
Baffled Sump
Rear Calipers
Roof
Clutch
Cat
Respray
Coilovers
Hub nuts
Drop Link
Engine Mounts
My first suggestion was doing the bushes until you said you didn't want to polybush it... reckon it's the one thing that'll really make it feel like a new car again. Why are you against it?
Member
I've had this one far too long
Possible record.
For LG, i'd say pipe and slippers
But on a serious note, bushes will be pretty worn with all your track driving. All the mounts are a good idea too.
Possible record.
UK Moderator
Too much hassle getting in and out see "pipe and slippers"
See above regarding ride comfort and getting in and out.
Keep em coming.
For the mounts would it just be 2 of 50810-S2A-003 (number 4 here): http://www.hondapartsnow.com/Page_Pr...ngine%20Mounts
Or am I looking at the diff mount as well?
Ello buddy, long time no speak.
I think bushings would be what I'd do if I was you. When I had mine done it just felt a lot... tighter? I did the uprated ARB's and chassis braces at the same time and I will say it was firm, but I guess its hard to say what caused that. I guess you could 'dial down' the dampers for day to day driving to compensate.
You can get new gearbox and diff bushes too, so consider those with the engine ones. From what I'd read, there is decent improvement going for harder ones in all these areas... but obviously you could end up with a bit more vibration....
