How to strap down the s2000 on a flat bed
Hi, I'm looking for some advice.
I need to trailer my s2000 about 900 miles. I read older posts saying to use R hooks and some say to use J hooks. Which do I use? Are these also the miniature hooks? Also, anyone have any pictures of the holes that the hooks go into? I read that "The front points are roughly below the mirrors. The rear points are about 6 inches in front of the rear tires. You want to have your tie downs running as directly fore/aft as possible."
How do you guys hook up the hooks to the straps?
Also, I think I need to go get some 2x4's and 2x6's to help load the car up the ramp cause I don't the s2000 can go up without damaging the front bumper.
I already moved my 1970 Fiat 500 by wraping the straps around the lower control arms. It was only 1100 lbs compared to 2900 lbs.
Thanks
Thanks
I normally trailer mine using Axle straps over the rear lower control arms, and though the front wheels. Now I do have a 36" axle strap for that. We used to use a 24" axle over the front lower control arm.
As for loading the car, that is your call.
Strapping down a car from control arms is never a good idea and also the wrong way of strapping a car down.
Use designated hook points on the chassis under the car & for added security you can strap from the wheel.
Over time you will bend control arms, might not seem like much but just imagine you tightening one strap more than the other.... More stress is on the one arm, combines with 900 miles of towing bouncing up & down.
This goes for towing an S and loading it onto a flatbed. Never let the tow driver J hook it to pull it up or use control arms as a tie down point.
I'd never heard anyone say that before, but something to think about: last year I set my car's rear camber to -2.2 degrees, then tied it down to a trailer by its control arms to tow it to the San Diego National Tour. When I got to San Diego, I found the car had near-uncontrollable oversteer; when I got it back on a rack, I found that I could no longer get more than -1.8 degrees of camber. I can't think of an explanation for my disappearing camber adjustment range other than that the control arms or adjustment bolts got bent in transit. I plan to tie my car down by its wheels from now on.
The correct way to tie down an S2K to a trailer is with R hooks. The holes in the sides in front of the rear wheels and behind the front wheels are designed specifically for these.
Use high capacity ratchet straps and proper anchor points on the trailer like D rings. Use at least 3 wraps on the ratchets and make sure they are locked closed. Make sure to take it out of gear.
Never use the control arms. That is a very bad idea.
I use the R hooks (http://www.awdirect.com/tie-down-hooks-ca15/hooks/). The oval shaped tie down holes in the chassis are covered up by a rubber cap.
As others have pointed out, those are the correct tie down locations provided by Honda. I wouldn't use any other method for towing my car more then a few miles.
You are basically pulling you're arms apart while trying to secure the car.
Not sure if this applies to privately towed cars but tow trucks require a 6 point tie down in CA.
