OK - Failed... oh, correction Success!
Old 02-02-2012, 10:01 AM
minvo's Avatar
Default OK - Failed... oh, correction Success!
Hi all,
Had my first attempt at "car maintenance" on the S2000 tonight.....
Objective: Install some Sokie Tech Dampers that I purchased from Tawain (get me - ordering stuff off fleabay!)
Result: Failed.
It seems that after installing them (I thought correctly) the bonnet doesn't close properly. I get an arch from front to back.
I must have something in the wrong place or the wrong way round.
Can anyone assist?
It may be that Left is Right and Right is Left. I put the "Left" one on the right side of the car (left as I looked at the bonnet).
Minvo.
Old 02-02-2012, 10:12 AM
Bramblecat's Avatar
Only ever seen them for the bonnet. Not seen them for the boot
Old 02-02-2012, 10:15 AM
minvo's Avatar
Posted edited to Bonnet.
Old 02-02-2012, 10:36 AM
Chad!'s Avatar
If they came with little brackets, you may need to mess with the angles of them a little. Possibly wrong side, but I doubt it. I think some of them have adjustment so can be sorted.
Chad.
Old 02-02-2012, 10:49 AM
unclefester's Avatar
Turn the dampers around so that they fit top to bottom from what the instructions suggest - they DO fit.
GaryB's Avatar
Can you post pics of how you have them fitted?
Old 02-02-2012, 11:13 AM
Kitesurfer s2000's Avatar
Rob 2.2 fitted mine and that happend its the brackets at the top mate round the wrong way .
Old 02-02-2012, 11:40 AM
GavB's Avatar
Did you put it on like this? Look carefully, I know someone who looked at this picture for 10minutes before seeing the differece between what they had done and what the picture looked like!
Old 02-02-2012, 11:55 AM
samg1988's Avatar
Mine are the same. Not had a chance to change it yet though.
My brackets are fitted as in that photo. From what I could tell, it was where they bolt into the wings that was the problem. The bolt with the round end that the damper snaps onto is too high I think. I took out a washer which helped a little... but not much.
Old 02-02-2012, 01:06 PM
PhilMartin's Avatar
I fitted some of these recently. I found it easiest not to follow the instructions and just basically guess how they should fit. It worked a treat. Taking them apart more than the form they came in helped, especially when trying to 'squash' them by hand to screw the damper rods into place.
Quick Reply: OK - Failed... oh, correction Success!
