s2000 secret compartment sub
kicker cvt8-4 inside secret compartment area. i never used the area much so why not. i might mod/remove the glove box area for another cvt8-4 inside, so that'll be two 8 inch subs in secret compartment that you cant see from outside when covers are closed!!im not real happy with the way the top came out so a replacement one is on its way (thank you jsenclosure)so that way the outside will just be little holes for bass to escape out of and i can still use the visor.
http://youtu.be/0_ipYedUWqU
its perfect because i dont even have to adjust bass in radio to full. adjustment goes from -10 - +10 and currently its @ 0. kicker 200.2 amp is set @ mid on gain/bassboost
I would throw some dynamat around the compartment. I can hear vibrating noises from there on the lows. I'd have to imagine when closed that the visor vibrates a lot too? Definitely interesting placement
