Sponsored by:
Sponsored by:
LM style wheels 18x8 18x9 et38 all around fitment?
Old 01-23-2012, 01:36 PM
warbucks's Avatar
Default LM style wheels 18x8 18x9 et38 all around fitment?
i recently just purchased a set of LM style wheels online and currently waiting for them to arrive,the company said that the wheels would fit on an s2k but after asking a few ppl they said they doubted the fitment...sizes are as follows (f)18x8 38 offset (r)18x9 38 offset....my question is if these wheels will fit without rubbing if i lower the car 2 inches? and if i do lower it(after rolling the fenders)what tire sizes should i use to avoid rubbing?thank you for any input possible
Old 01-23-2012, 01:54 PM
FISH22's Avatar
Camber and fender rolling will be your best friends.
The fronts should be pretty easy to fit. What tire sizes are you planning on running? With up to a 225 in the front, all you'll need is a good roll. But if you plan on running a 255 out back, you'll have to run a good amount of negative camber(atleast -3.0), have the fenders rolled completely flat, and trim a lot of the bumper away. Running a 215/245 setup would make things a lot easier.
Old 01-23-2012, 03:30 PM
ryuken's Avatar
I hope it works out for you and not end up like this guy here. His offsets are just a tad different from yours and maybe it's a different company but his spokes hit the rear calipers. https://www.s2ki.com/s2000/topic/896...-calipershelp/
Old 01-23-2012, 03:59 PM
warbucks's Avatar
i was going to go 215/40/18 in the front and 235/35/18 in the rear for clearance so id have to use less camber...i might have to sell these as soon as i get them if theyre going to be too much work
Old 01-23-2012, 04:13 PM
warbucks's Avatar
and they look to be the exact wheels to a T.....arghhh
Old 07-02-2012, 05:39 PM
adamjames6996's Avatar
Hey. Did these ever work out for you? With a 38 offset I don't think it should of been a prob. It's the 18 inch part I'm scared of
Old 07-02-2012, 06:09 PM
S2k007's Avatar
If you're using the correct tire profile then it doesn't matter if the wheel is 17 or 18 inches or any size, the overall diameter of the wheel/tire will be the same. It's the offset and tire width (which is related to wheel width) that determines whether you'll rub or not.
Old 07-03-2012, 06:20 AM
Ok, so the wheels I'm gonna get are 18x9 offset 38. 18x8 offset 38. Would a 225,40 18 work out for the rear? Idk to much about wheel stuff lol
Old 07-31-2012, 09:23 AM
Chanh55's Avatar
What tire size did you end up with? Any updates?
Old 07-31-2012, 11:12 AM
RedCelica's Avatar
Last active: Mar 11 2012 11:44 AM
Quick Reply: LM style wheels 18x8 18x9 et38 all around fitment?
