Intake cam starved of oil, catastrophic failure.
Old 12-31-2011, 10:59 AM
AE_Racer's Avatar
Default Intake cam starved of oil, catastrophic failure.
I did some research to find i'm not the only one to experience the intake cam losing oil. However I couldn't find any solutions or answers. I didn't catch mine before it did this:
Cracked cam caps, quite obviously the cam and journals are all screwed.
Now before its said, I didn't notice anything out of the ordinary, no super odd noises or anything that would make me inspect. I drive the car 160 miles roundtrip to work everyday so I know it pretty well. Friday morning on the way to work, it shut off when I came to a stop. Started right back up, no big deal. A few miles down the road it shut off indefinitely. After finding the above, the cam sprocket was also loose which I assume is what caused it to shut off.
Now, my question... In my shoes, what would you guys do? It seems that the lower journals are seperate from the head, i.e. they can be replaced, is that true? (Haven't looked hard enough yet) Essentially I could replace the cam, and all the caps/lower journals, re time it (hoping no valves hit the pistons), and be good to go. However I still don't know what caused this issue so it could happen again.
The good stuff, before questions are asked:
I do not know the actual engine mileage. Car has 195k, but I was told the engine was replaced. No proof/receipts were given so i'm going to guess 195k is actual mileage.
I keep up on my oil changes, I use Wix filters with valvoline 10w30 dino oil.
No changes had been made to the engine reccently.
Thanks!
Old 12-31-2011, 11:17 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Just had this with a customer...the front cam wheel bolt came loose. Immediate loss of oil pressure to the top end.
Loose cam sprocket caused the whole thing.
Old 12-31-2011, 11:18 AM
Billman250's Avatar
Look inside the valve cover...you see a circular mark from the cam wheel hitting the valve cover?
As long as the cam wheel bolt is tightened properly, this wont happen again. I promise
Old 12-31-2011, 11:29 AM
AE_Racer's Avatar
So the cam sprocket caused the whole thing? Crazy! lol
Thank you. What is your suggestion for the repair, good sir? Will it require a whole new head or can the lower journals be replaced?
Old 12-31-2011, 01:38 PM
Slows2k's Avatar
Seen this with oil filter relocators installed incorrectly.
Old 12-31-2011, 02:30 PM
Utah S2K's Avatar
Seen this once. I frequentlywonder if some of the lubrication issues are related to running non-spec oil......which you are. I run 10-30 and have periodically worried about it. Are you in the cold or are you in a warmer state? Currently collecting data as most run 10-30 but Manual says 5-30. Oil orifices on the F-20 C are comparatively small.
Utah
Old 12-31-2011, 02:38 PM
AE_Racer's Avatar
I'm in north Florida. Most of the year is 80-100*F.
And no oil filter relocator here, for the record.
Old 12-31-2011, 03:12 PM
Utah S2K's Avatar
Lucky bastard
Old 12-31-2011, 03:20 PM
AE_Racer's Avatar
Originally Posted by Utah S2K
Lucky bastard
I dont know why people think so. Those kind of temps plus crazy humidity to go with them is no fun
Old 01-01-2012, 04:15 AM
SpitfireS's Avatar
Utah
As this happened at operating temperature the difference between 5W-30 and 10W-30 is nothing.
IOW: oil was not the cause of this.
The varnish is a typical sign of years of dino use.
Varnish settles on high temp & low oil pressure & flow area's, not in oil passages.
We should not use the OP's misfortune to promote 0W or 5W oils.
This has nothing to do with oil.
OP: do you remember seeing the oil pressure warning light at all?
The loss of oil pressure was probably low enough to not trip this light but high enough to cause this damage.
The darker color of the varnish could also mean it happened instantly instead of a slow leak over a longer time.
Even in a couple of miles are a LOT of revs, and revs without oil means lots of heat.
Quick Reply: Intake cam starved of oil, catastrophic failure.
