Sponsored by:
Sponsored by:
Rear wheels wont clear calipers...help!
Old 09-10-2011, 10:37 AM
hamy's Avatar
Default Rear wheels wont clear calipers...help!
So I've been waiting all week to mount up my new wheels/tires only to find they won't bolt up over the rear calipers. The wheels are 18x9 +40 w/ 245/35/18 tires. Fronts are 18x8 +35 w/ 215/40/18s. Fronts are perfect fit fine. But the rears won't bolt up due to the bracket on the outside of the caliber. Its only about 2-3mm of required clearance. So...what now? Sell um? Add a 5mm spacer and risk even more rubbing? Trim the caliper bracket? I'm running -3 camber, trimmed rear tabs and fenders. Was running a 17x9 +45 w/ 255s no problem. Help!!
I can see the problem with the wheels...they have very low back spacking to make a hugh lip.
I hate to sell them because they are brand new and I just dumped a bunch of cash into them.
Old 09-10-2011, 12:11 PM
TTMartin's Avatar
I'm guessing you are talking about the bracket that holds the e-brake cable.
The best thing would be to run a little less camber, which I would do over a spacer.
You could also grind a couple of mm off of the bracket and be done with it.
But, I'm not recommending that you do that, and take no responsibility if you decide to do so and have no e-brake when you need it.
Old 09-10-2011, 01:46 PM
hrpfg2's Avatar
thats odd...
best bet will probably be spacers.
btw, these are authentic LM's right?
Old 09-12-2011, 05:34 AM
jeffbrig's Avatar
That won't do anything. Any camber change will simply tilt the hub/brake/caliper/wheel assembly together as a unit. It won't create any additional clearance.
Old 09-12-2011, 02:54 PM
TTMartin's Avatar
I agree and stand corrected.
Old 09-13-2011, 10:07 AM
clarkster009's Avatar
If you use a 5mm spacer you will need to replace your studs with longer bolts. In addition that will drop the offset to 35 which is even harder to fit.
Old 09-14-2011, 07:57 AM
hamy's Avatar
Thanks for the input guys. Just to be clear...the inside of the rim face is hitting the outside of the caliper bracket. So my plan I guess is to add a 3mm spacer in hopes of pushing the wheel out enough to clear the caliper, but not too much as to have even more rubbing on the fender. Talk about a tight fitment. I hope to post pictures by the end of the week.
Old 12-29-2011, 12:08 PM
sdosmil77's Avatar
sory 2 bring up old thread but whos the seller? have u contacted the seller on problem? i was actually thinkin these from this guy. i already am happy w the rota d2's i got from him so mayb these could b my extra wheels?
http://www.ebay.com/itm/400265194339...84.m1423.l2649
samrahhh
08-15-2015 06:14 PM
rsxiness03
04-17-2012 07:29 AM
burglrdrift
02-22-2012 04:47 AM
iFRYrICe206
15
10-06-2011 05:27 AM
Blue_AP2
08-27-2008 03:38 PM
Quick Reply: Rear wheels wont clear calipers...help!
