Smog check
Smog check
Hey guys, so I just receive my renewal and I was required to have a smog. So my current mod is j's header and 70rs with berks highflow cat and a comptech ice box, so my question is what do I have to remove inorder to pass??? Thanks in advance..
The J's header does not have CARB EO#, so yes you will need to remove it to pass visual.
Does the Berk HF CAT have a CARB EO#? If not, that needs to be taken off as well.
Comptech should be exempt, but make sure you have the label or can provide the smog tech with the correct paperwork.
I think something like a header is hit or miss depending on where you go. I had cars with aftermarket headers and intake smogged with no problem. There has also been times where a smog tech looks for ever carbEO sticker possible.
If you can find a smog tech who doesn't care about the visual as long as the emissions passes then u can probably leave the header on. But the HFC most likely will fail the emissions part. I had my smog last year with an AEM V2 cold air intake (it did have a carb #) and a JVT header (not sure if it had a carb #), and invidia V3 cat back exhaust and I passed the emissions, so he let me go. I forget which shop I went to.
But Vu is right, if the smog tech goes by the books, you will need to remove the header and HFC. Good luck, the header is a PITA to remove.
He will be able to leave the HFC cat in if has a CARB E.O. # (and cat installed so EO# is pointed down). Just a side note, if the HFC is more than 3 years old it will probably fail tail pipe emissions, but that is just my experience.
