Supra V160 Getrag Conversion
#382
Jesus, thats not bad at all........maybe I will do this sooner than I thought. . Whats the deal with the clutch required for this, it has to be one of the special $2,000 twindisks correct?
#383
#384
wow i found one new for 5,500, but im glad i didnt jump on it yet after seeing that ebay sale, and joey u need the cultch masters twin disk from full blown to make this work
#388
I know thats the reason I was. I babied the tranny and shifted it slow, which KILLS your time, and on a turbo car, easier to fall out of your powerband.
#389
If anyone is buying a new V160, I've compiled a parts list new from Toyota, that you will need to complete this swap.
This is the cheapest place online that I have found these parts: https://www.1sttoyotaparts.com/
Here is a diagram of the stock shifter and mount.
Shifter Assembly:
33530-14442 - 93.5-95 Shifter Assembly
33555-14100 - Upper dust boot (optional)*Will need to trim Full Blown Bracket to fit*
93381-16016 - Screws with Washers (4 are needed)
33556-14050 - Seat for shift lever ball
90387-08134 - Collar for shift lever and linkage (2 are needed)
90301-11015 - O-rings for collar (4 are needed)
90105-08200 - Bolt for linkage and shift lever (2 are needed)
90179-08095 - Nut for bolts (2 are needed)
33513-22030 - Yoke for Linkage and shift lever
33531-14010 - Dust boot (Optional) *You will have to modify this for the linkage to pass through*
90467-21010 - Retaining clamp
90250-06026 - Pin for linkage
Transmission Mount:
12371-46110 - OEM transmission mount
90179-08159 - Nut (4 are needed)
*Optional*
12371-JA800 - TRD urethane tranmission mount *Google part # for other sources to purchase ranging from $85-100*
31123-14020 - Inspection Cover *Driver's side will need to be modified for clutch lines*
31121-14030 - Inspection Cover
90080-11228 - Bolts for inspection covers (4 are needed)
08885-01306 - Toyota V160 Transmission fluid (2 cans required, need 1.8 liters transmission fluid to fill transmission)
The shift knob will not work from your S2000 as it is a 10X1.50 and Toyota is 12X1.25
Hope this helps
Cheers
Shifter Assembly:
Transmission Mount:
*Optional*
Hope this helps
Cheers
#390
Shifter Assembly:
Transmission Mount:
90119-08770 - Bolt (4 are needed)
90201-11013 - Washer (4 are needed)
*Optional*
Hope this helps
Cheers
Shifter Assembly:
Transmission Mount:
*Optional*
Hope this helps
Cheers
