Sponsored by:
Sponsored by:
17 x 10 +35
Old 08-01-2011 | 07:34 PM
wisdom's Avatar
Default 17 x 10 +35
Car has coilovers, so height can be changed. Currently car has about 1 finger gap all around with 225/50/16 and 245/45/16 tires. Any advice on how to fit the rears? Roll, pull, relocate and trim? And probably about 3 degrees of camber?
Looking to see pictures of rear setup and tire sizes.
Thanks.
Old 08-04-2011 | 03:56 PM
Jim@tirerack's Avatar
With that wide of a wheel and the needed wider tire and the lower offset I can see a wide body or pulling the fenders out to make it work.
Old 08-05-2011 | 05:50 AM
TubeDriver's Avatar
Thanks.
Run 195/30-17 tires?
Old 08-05-2011 | 06:06 AM
clarkster009's Avatar
If you want any functionality at all you need overfenders.
Old 08-05-2011 | 06:18 AM
wisdom's Avatar
Well after chatting with a memeber, it appears it takes more work than expected. I'll stick to something more feasible.
Old 08-05-2011 | 06:43 AM
RedCelica's Avatar
good plan
Old 08-05-2011 | 01:34 PM
ed-gsxr's Avatar
definitely made the ride choice. i dont think its worth all that trouble to make it fit.
Old 08-06-2011 | 10:43 AM
Y0N1P8T5R1F5A4T's Avatar
hey wisdom, my new wheel and tire setup is a lot more fender friendly from the old 17x9/10 +35 setup. im going with 17x9 +45 w/ 255/40/17 and im gonna raise the car up a little bit to be track friendly. do a basic fender roll on all corners. i won't have any pictures soon as the wheels are still in the process of japan making them.
jdmdohcpower
02-23-2014 11:34 AM
ap1s2k808
01-10-2014 05:09 PM
sandcastle
05-18-2013 08:29 AM
Trent06
10-27-2010 02:03 PM
McD Effect
06-19-2009 07:57 AM
Quick Reply: 17 x 10 +35
