Acceleration vibration
I got this vibration on my car (02 ap1) when I accelerate I don't know what it is anymore! It's really making me sad. My car is lowered on buddyclub n+ which I have installed axle spacers to stop the vibration then It came back about half a year after lowering it.
Things I have installed/replaced
Axle spacers
New Axles
Propeller shaft
New outer tie rod ends
Any ideas/input will be appreciated.
Axle spacers
New Axles
Propeller shaft
spacers mask the problem for a short time, then it returns.
ALXE BUCKET SWAP is the cure. Repalcement axles that are not honda dont run at the precision that the oem axles do.
So the problem points back to my axles? I replaced the OEM ones cuz they were bad then I ordered a pair from NAPA auto parts.
Thats your problem.
Pull the buckets off the stock axles and check them for pits. if so, swap the buckets side to side and put them back in.
LEAVE THE SPACERS out.
