Odyssey yellow fog lights
Doesn't look bad. I probably would have gone with tinted so it would blend in more and from a distance ppl would probably think it was just your normal grills. Nonetheless...looks pretty good. How hard was the install?
i would say moderate difficulty. cut out the faux vents, fabricate some brackets, glue around the gaps. the wiring was easy, plugs right into the fuse box and turns on when lights on(city or headlights). I have a switch also, but i just left it in the on position.
