Master Cylinder Went Out
I noticed the clutch pedal losing pressure this morning but the car still shifted fine. I just went out and could not get it in gear. The pedal has no pressure and sticks to the floor. The fluid is low as well (I topped it off last week). Sounds like the master cylinder, right? Anything I should check for? It's a 2003 with 65k miles.
Check in the floorboard by the clutch pedal. See if it is leaking there. If it is, best bet is to replace it with a new one. Some have had luck just refilling with new fluid and leak stops by itself, but I was not so lucky. Replaced mine and have been fine ever since. Make sure to adjust the new pushrod properly, (I follow Billman's zero play adjustment)
Mine has a slow leak and needs to be replace sometime soon. I stumbled across this last night, anyone tried it as a better alternative to just an oem replacement since the MC is a wear item in reality anyways. They are probably similar in price to the Honda version but this is an upgrade maybe?
http://www.kingmotorsports.com/p-489...der-s2000.aspx
the omni power has so bad reviews associated with it on this site, if you search a little more. Personally I've never used it so no comment. The clutch master is pretty cheap on the Majestic Honda website, check it out. I also suggest changing out the clutch slave while you're messing with the hydraulics. I regret not doing both at the same time. (some dirty fluid contamination, even though I bled it 12312890 times.)
Yeah, no fluid on the floor. It's leaking on the ground. I topped it off and it shifts fine. The pedal does still feel a little weak. I'm gonna keep it topped off until I can replace the master and slave cylinder. Majestic Honda has great prices! Anyone have a good DIY?
Keep the fluid clean. replace just the fluid in the res every 5k miles, no need to bleed. The leak will stop.
DO NOT get an omni MC. They are garbage.
it is your clutch master cylinder. one day i was at work and got back in the car and as i was driving the pedal was stating to feel way to soft until finally it just stayed on the firewall so i check and its a common problem on ap1's. if you cant afford a CMC at the moment you can stil drive your car by jacking up your car and right next to the transmission you will be able to see the bleeder nipple and all you have to do is pour some brake fluid and pump out the little air bubbles that got in there not too hard just keep an eye on it. usually they leak from the actual piston where the clutch pedal is located where you see the piston going in and out. thats what i did and just keep an eye on the levels of the CMC and youl be good.actually mine didnt leak that much and i went almost a year like that and when i replaced it, it felt the same so thank god i didnt do any harm to my clutch. because thats very costly. good luck
