Mark this thread as Sold
Koni 8242 (aka TC Kline) double adjustable shocks - No longer for sale
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-15yr.png)
5/24 edit: I didn't get a lot of response to my first post, so I've put the shocks back on my car -- they're no longer for sale. Thanks for the interest!
I'm selling my Koni 8242 double adjustable shocks. These are also sometimes known as "TC Kline" shocks. These are *not* just revalved Koni Yellows -- compared to Yellows, the 8242s have much larger shock bodies and shafts, and were designed as double-adjustable shocks from the start, instead of being converted to doubles after the fact.
My shocks were rebuilt and revalved by Jeff Wong at ProParts USA in August 2010. They were repainted standard Koni yellow as part of the rebuild, in case you're wondering why they're not white like other TC Kline shocks.
I've put a few thousand street miles and a handful of autocrosses on them since the rebuild.
It's a pain in the behind to adjust the left rear shock, so I had a low profile adjuster custom fabricated. It stays on the shock at all times (although it's removable), and makes adjusting the shock somewhat easier.
Full disclosure 1: The brake line mounting tab on the front shocks interfered with large aftermarket sway bars (I run a Gendron 1.375" bar), so I cut it off. The paint used to cover the spot where the tab formerly attached doesn't match the rest of the shocks. This is visible on the leftmost shock in the picture.
Full disclosure 2: 8242s clunk when cold. This is not indicative of a problem with the shocks -- they all do it. Whether you care depends on how sensitive to NVH you are; I find it annoying, but I also run a stock exhaust because I find even aftermarket doubles too noisy.
Comparable double adjustable shocks from Penske, Moton, JRZ, and AST are well over $3000 new.
Thanks for looking!
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Thanks for looking!
![](https://pic90.picturetrail.com/VOL2205/2669804/5516744/396407700.jpg)
They were revalved for SCCA Stock class autocrossing, although I imagine the valving should also be appropriate for stiffer-than-stock springs in other environments.
These are the same basic shocks that Marc Pfannenschmidt was running when he won B Stock at the 2010 national championships, although he may have different valving.
Front football:
![](http://pic90.picturetrail.com/VOL2205/2669804/5516744/396414698.jpg)
Front force vs. velocity:
![](http://pic90.picturetrail.com/VOL2205/2669804/5516744/396414699.jpg)
Rear football:
![](http://pic90.picturetrail.com/VOL2205/2669804/5516744/396414700.jpg)
Rear force vs. velocity:
![](http://pic90.picturetrail.com/VOL2205/2669804/5516744/396414701.jpg)
50 mm. Koni sells 50 mm sleeves; I imagine a standard 2" sleeve would also work (50 mm == 1 31/32"), but I haven't tried it.
Thanks!
Front football:
Rear football:
Thanks!
Originally Posted by neurotic' timestamp='1303699520' post='20503177
(1) what were they revalved for?
The stock TC 8242 was built for the Car and Driver s2000 in T2 many years back. All the valving was for road racing, but carried over very well to auto-x. These are a good mid range shock that fall between the Koni Yellows and Moton/Penske/etc.
-Marc
DaveMunsey
Member S2000 Classifieds and For Sale
11-02-2017 12:35 PM
PedalFaster
R&C Parts For Sale
10-15-2012 10:31 AM
PedalFaster
R&C Parts For Sale
05-24-2011 12:53 PM
