how to reset steering torque sensor - NO Honda PGM Tester
Old 04-15-2011, 11:40 AM
klkev99's Avatar
Default how to reset steering torque sensor - NO Honda PGM Tester
Hi all
i want to reset my torque sensor, but i dont have a PGM tester
i read the 17-45 manual
i also have a few Qs
1: What and where is the SCS circuit
2: i am no mechanic, but how do i short the SCS circuit to ground? using a wire? short it to the body?
3: can someone post a full step by step details of how to?
your help will be very helpful, as i could not find anyone that knows how to do it.
thanks
Kevin
Old 04-15-2011, 11:08 PM
klkev99's Avatar
Guys i really need some light here
Old 04-16-2011, 03:02 AM
klkev99's Avatar
BUMP
your help will be much appreciated
Old 04-16-2011, 09:11 AM
Thunder-rush's Avatar
My EPS worked ramdomly, I did everything, traced wires, measure voltage,etc. In the end, bought a EPS unit in Ebay and was done for the day.
Here is the procedure.
With the car off, and the wheel straight do the following
1. Using a paper clip or backprobes, connect PIN 9 to PIN 4 on the ODBII connector.
2. Turn the steering wheel 45 degrees to the left
3. Turn the ignition switch on (II)
4. The EPS Light will be on for 4 seconds, when it goes out do step 5
5. Turn the steering wheel Straight, and release
6. The EPS Light will turn on in 4 seconds, when it goes out do step 7
7. Turn the steering wheel 45 degrees to the left
8. The EPS Light will be on for 4 seconds, when it goes out do step 9
9. Turn the steering wheel Straight, and release
now the EPS light will blink twice after you relase the wheel, within 4 seconds. then it will blink 5 times.
If the EPS light stays on, you will have to do this process again.
Old 04-16-2011, 09:12 AM
Stratocaster's Avatar
1: What and where is the SCS circuit.
it is in the ODBII port. That is where the Honda Tester is pluged.
I normally use the ground wire in the ODBII port. Jumping pin 4 and Pin 9
BTW the search really works. That is how I found this to post for you.
Old 04-16-2011, 10:16 AM
Croc's Avatar
does this eliminates the need for Honda's PGM tester?
how do you know that you turn steering wheel at exactly 45 degrees and not 43 or 47?
this is impossible to judge by eye...
Old 04-16-2011, 11:18 AM
klkev99's Avatar
thank you so much
but could you tell me which is pin 4 & 9? where to i count from?
Old 04-18-2011, 07:00 PM
There is numbers in each of the corners. Take a light and your glasses (I wear them, so everyone must too) and take a look. if you can't read it, I will take a look in the shop manual in the morning.
Old 02-08-2012, 06:52 AM
RobinA3's Avatar
Hey guys
I am trying to reset my EPS however i don't seem to have pin 9 on my OBD port, there is no wire going into it. Anyone shed any light on this?
Old 02-08-2012, 06:57 AM
blasphemy101's Avatar
I very recently did this on my S, and it definitely had a number 9 pin. It's in one of the corners. I noticed I had to put the wire I was using very far into the holes before they would make connection.
Quick Reply: how to reset steering torque sensor - NO Honda PGM Tester
