Alloy Craft fuse box heat shields
Alloy Craft's newest release is a replacement heat sheild for your fuse box area. This sheild will replace your stock exhaust manifold heat sheild, as well as add some sheilding to the fuse box and battery area. Our heat sheilds also come standard with a knock out panel for those running engine torque dampers. They are also avaliable without knock out.
If you are intrested in purchasing one you can send payment to
Sales@alloycraft.com
This item is avaliable in 2 versions and both are currently instock.
1. Mirror polished stainless steel, total weight 3 pounds: Retail price $175
Part numbers
Stainless steel with knock out panel for engine torque damper = SSK01
Stainless steel without knock out panel = SS001
2. Black powder coated 5052 aluminum, total weight 1.5 pounds: Retail price $130.00
Part numbers
Aluminum with knock out panel for engine torque damper = ALK01
Aluminum without knock out panel = AL001
Also for those who are intrested in our radiator cooling plate (shown in pic 4, 5 ). For a limited time, with purchae of a heat sheild, you can add a black one to your order for only $75.00 !!
Pictures of the mirror stainless steel.
Part numbers
Part numbers
Originally Posted by ans2k,Jan 4 2011, 12:04 AM
if i get a black one, will it have a pre-cut hole? b/c i dont want a hole for my non-existence ETD
Originally Posted by retvet,Jan 4 2011, 01:55 AM
As an owner of one of your engine-turned sparkplug covers, I will say you are doing wonderful work. Will the heat shield and the radiator cooling plate be available in engine-turned?
