how to set timing!
Old 09-07-2010, 06:57 PM
hypforlife32's Avatar
Default how to set timing!
hey guys im in the middle of doing my retainers, and i need help setting timing. what notces on the bottom pully should i use. there is a pink one and white one.
Old 09-07-2010, 07:24 PM
jeggy's Avatar
two lines on the gear opposite of each other line up flat with the cylinder head.
Old 09-07-2010, 07:27 PM
im talking about on the bottom crank pulley. there are a few marks down there and im wondering which one you need to be lined up with the arrow
Old 09-07-2010, 07:30 PM
jeggy's Avatar
i didn't have that info when i replaced my cylinder head so i just took a metal coat hanger and dropped it in the #1 spark plug hole and turned the engine over till the end of the coat hanger reached it's highest point. thats TDC.
Old 09-07-2010, 07:31 PM
okay awesome, and one last thing. what are the torque specs of the brackets on top of the caps?
Old 09-07-2010, 07:51 PM
jeggy's Avatar
if you're referring to the cam towers, it's not a whole lot. somewhere around 20 lb-ft if not less. but i don't remember exactly.
Old 09-07-2010, 10:52 PM
Yeah that's what I was referring too. We torqued them down to 16 lb ft. I found what they where supposed to be at. Now I ran into a MAJOR problem. At first the car started fine, then the 2nd time I started it it had a weird sound. Then I continued on my way home and 15 min later I stopped at wawa and now my cel is on and my car won't start. Its making a weird grind sound after 2-3 cranks. I have no idea what's wrong. I'm terrified something is broken.
Old 09-08-2010, 03:36 AM
drhess06259's Avatar
i would pull the head and check your work might not have put a retainer back on corect or tighteden something down correctly....
Old 09-08-2010, 03:41 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Pull the valve cover. Don't touch the key anymore.
Old 09-08-2010, 06:14 AM
Yeah I won't touch the key anymore. I'm going to get it towed today.
Quick Reply: how to set timing!
