Air Temp sensor on intake
Old 07-21-2010 | 05:05 PM
smallville160's Avatar
Default Air Temp sensor on intake
hey so the previous owner of my S went and bought a cheap POS intake. since then i have gotten a much better one. my problem is i dont know what he did with the air temp sensor that was on the stock intake.
does anyone have a diagram so i can figure out were the wires from this sensor run and help locate the thing or possibly just some detailed pictures if you have a stock intake and can show where the wires from the sensor run? thanks guys
Old 07-21-2010 | 05:16 PM
Elroy's Avatar
There is an online Service Manual for a 2003 S in pdf format somewhere on the net. You can track down the wiring for the Intake Air Temperature Sensor which should be the same or similar to your MY.
J
Emil St-Hilaire's Avatar
Old 07-21-2010 | 06:02 PM
Slows2k's Avatar
The IAT sensor on 00-05 cars is in the intake manifold, and is not relocated with any of the bolt on CAI's. It is held in with 2 Phillips headed screws.
Only the 06 and later cars mounted the IAT sensor in the intake tube, not the manifold.
Old 07-21-2010 | 06:21 PM
swervin zx6r's Avatar
What kind of intake did you get? Ad what year is it for?
Your info says you own a 2000. With 2000 to I think up to 2005 the IAT sensor is mounted on the actual intake manifold, And for 2006 and up its mounted on the actual intake tube.
So if its just an intake you wouldnt even need to get to the IAT sensor. Hope this helps
Old 07-21-2010 | 06:22 PM
DANG!!! Slows2k beat me too it!!! I need to learn how to type everything im thinking faster lol
Old 07-21-2010 | 11:18 PM
H22toF20's Avatar
^what those 2 said.
Old 07-21-2010 | 11:38 PM
hahaha awsome thanks i only mentioned it because i say some S's with them on the intake tube they must have been 05 and up i will double check and see if i have one on my manifold in the morning i was just worried the idiot before me may have cut the wires and hid them or something since the intake was kinda MacGyver-ed in there
Old 07-22-2010 | 07:32 AM
alSpeed2k's Avatar
^pic of said "cheap POS intake."
99SH
10-15-2018 08:24 AM
Jayhennessy93
07-19-2016 05:36 PM
midtenvol
02-22-2012 09:41 AM
maluch
06-30-2008 06:14 AM
MB
10-17-2005 12:54 PM
Quick Reply: Air Temp sensor on intake
