VSA Light
VSA Light
Hey guys, I just installed an aftermarket steering wheel and now my "VSA" and "!" light are on now..
Is there someway to reset this? Is it suppose to be on?
Tried reseting ecu but no luck,
thanks for any help
thanks for any help
What brand hub did you use?
Make sure all the notches in the hub align with the steering column end. If I remember correctly, there's an extra notch for the VSA. You can easily dremel out a notch in the hub to account for this. The VSA needs this as a steering position sensor.
zakazak
03-31-2014 04:58 AM
