Power Distribution Block that is fused/switched?
I want to order a distribution block to clean up my wiring and need advice/suggestions.
I am using this to power gauges, a CB radio, radar detector, laser jammers etc but NO stereo equipment like amplifiers that draw a lot of power. I would like to wire the block so that all of these things are on switched power. I find plenty of dist blocks that have fuses when I search, but none with wiring allowing them to be switched on with the ignition.
Currently, I have everything wired into the fuse box with those "add-a-fuse" circuits and it works fine, but makes for long/messy wiring under the dash. I figured a block would clean this up and would also make it very easy to diagnose any problems if they were ever to arise.
I have the general idea down but am unsure about the specifics in terms of what I need for hardware. I have an old block I used in another car to power amps, but the amps had their own inputs for switched power so it wasn't an issue.
