DIY S2000 Tensioner and Serpentine Belt
Old 02-26-2010 | 07:18 AM
ljsimp's Avatar
Default DIY S2000 Tensioner and Serpentine Belt
Remove S2000 (F22C) Serpentine Belt & Tensioner
Tools required:
14mm socket/wrench/extension
Needle nose pliers
10mm socket/wrench/extension
Flat head screwdriver
Torque Specs
2 x Tensioner bolts (8 x 1.25mm) = 16 lb ft
Pully Bolt = 31 lb ft
Note
You do not need to change the tensioner, or remove the airbox to change the belt. I had to replace my tensioner that is why it is in this instruction. Removing the airbox makes removing the belt, and reinstalling easier.
1. The first thing I recommend is to draw out (or take a picture) of the belt and pulleys so you know how to install the new belt.
2. Remove the tension off of the serpentine belt (drive belt). This is easier than a beginner would think. To do this put a 14mm socket on the 14mm bolt and turn counter clockwise. You will notice that the tension will release. Slip the belt onto the 14mm socket.
3. Remove the 4 10mm bolts from the air box. There should be a 10mm bolt in each corner of the air box. If you have a CAI your lucky!
4. There will be wires attached to the air box closest to the engine just detach them.
5. Remove the clamp hitched up to the throttle body.
6. Remove the hoses/wires attached to the intake.
7. Remove the tensioner
a. #7 metric hex for center bolt
b. 14mm bolt for bottom of tensioner
Recommendation - While you have the tensioner and air box off you could clean up the engine following Engine Cleaning Tips by krshultz.
https://www.s2ki.com/home/2010/02/26/s2000-...detailing-tips/
8. Install new tensioner the same way you removed the old one.
9. Install the new belt; follow your picture, or written instructions you took in step 1.
10. Check your belt make sure it’s on each pulley correct (aligned in the grooves).
11. Install the air box the way you removed it, check to make sure all cables/hoses are attached.
12. Check all your work; make sure everything is in the correct place.
13. Check your work again.
14. Start your engine, drive around the block.
I am not sure on the torque specs for the bolts so if anyone has them please post.
Also technically it makes more sense to take out the airbox first, snap a picture of the belt, and then remove the belt and the tensioner but no matter you will come to the same result.
If anyone wants extra security in their car you could pop the hood, slip off the serpentine belt which would take 10 seconds, and I guarantee no one will take your car with ease
Thank you
Old 02-26-2010 | 07:52 AM
batguano's Avatar
Great writeup. Thank you for the pictures.
I'm getting ready to replace mine soon.
Old 02-26-2010 | 08:32 AM
spets's Avatar
Does the airbox have to be removed if you are simply replacing the belt, or is there enough room to route it with everything installed?
Old 02-26-2010 | 09:13 AM
ljsimp's Avatar
If you have fairly small hands you have plenty of room to change the belt with the airbox in. Just pull back on the tensioner pully, take a visual image or snapshot of how it goes on. Pull it off quick and put new OE one on.
The belt takes 5 minutes its the easiest job I have done in a long time, Honda FTW!
The airbox is pretty easy to take off if you want a better visual of how to put the belt back on + more room to work with.
4 Bolts, and a few hoses and its off!
rail157's Avatar
Do I need to perform this in a field, or will my driveway do?
Old 02-26-2010 | 09:18 AM
ljsimp's Avatar
lol nice catch. Unfortunately my driveway is not level so the front of my house on my lawn is the best bet. To top it off I did most of the work with a spotlight in the pitch dark but that is just because I am determined when I start a job.
The belt takes 5 minutes its pretty easy. It can be done in a field, in the woods, in a pond (w/oxygen tank), or in a garage (spoiled).
Old 02-26-2010 | 03:44 PM
parkerdt's Avatar
Nice work, and nice write-up!
Dave
Old 02-26-2010 | 05:03 PM
zeroptzero's Avatar
hmmmm, I just did this job recently. I didn't remove the air box and I didn't remove the tensioner. It took a couple tries getting the belt in the right way but I got it done without much fuss. thanks for the write up. I put in a Goodyear Gatorback belt, less cost than the Honda belt and I think it's a better design as well (runs quieter and cooler)
Old 02-26-2010 | 06:17 PM
ljsimp's Avatar
You do not need to remove the airbox, or the tensioner but I had a bad tensioner so that is why I added that step. I recommend removing the airbox if you want the process to go a little easier but it is not necessary as stated. I go OE on only parts which I feel are very important like belts, tensioners, etc...Other stuff I go to a auto store.
Just me everyone is different.
Thanks
Old 02-26-2010 | 06:39 PM
zeroptzero's Avatar
ah that makes sense if you change the tensioner. Yeah removing the air box will make the job easier improving access to the front of the engine. How do you know if you have a bad tensioner, does it have weak tension ?
