water in headlight
Old 10-19-2009, 08:24 PM
keemaca's Avatar
Thumbs up water in headlight
whats up fellow s2k'ers im hoping i can get some help with this ..i had some condensation in my left headlight so today i removed it planning on trying to fix the problem i dried all the water in there and resealed it, everything was looking good but as i started putting everything back i notice the hid and signal light werent working signal light only works when i turn on the signal to make a left ..i dont have any idea what it could be i checked fuses,bulbs and they look fine i dont know if maybe as i was moving it around while drying it water got in the wrong place and messed up the headlight ...so if any one has any advice or ideas of how i can fix this or what may be the problem before i go get ripped off somewhere to find the problem it would be verry helpfull...
Old 10-19-2009, 09:39 PM
CKit's Avatar
Try swapping bulbs left to right to see if that's the problem. Double check your connections, too.
Old 10-19-2009, 09:49 PM
keemaca's Avatar
i checked the connections and nothing havent tried swapping the bulbs thought but they looked fine gonna try that tomorrow though ..anymore ideas..?
Old 10-19-2009, 09:50 PM
chansta's Avatar
if swapping light bulb works most likely connection.
Old 10-19-2009, 09:59 PM
keemaca's Avatar
just checked the headlight theyrs condensation again guess i didnt seal it right must be the cold weather maybe ill need another headlight...all that work to took me around 4 hours if not more..
Old 10-21-2009, 07:23 PM
keemaca's Avatar
could it be the ballast..?
Old 10-22-2009, 06:43 AM
my2ks2k's Avatar
definitely swap the bulbs side to side to check them first.
i'm confused about the signal light. you said it only works when you turn on the signal to make a left...when else would it be on? did you try hazard?
when you reseal the headlight, you have to make sure you put a LOT of silicone sealant, especially if it runs at all, and make sure you don't leave any gaps in the coverage, even tiny ones. best to go over the whole thing once, then go back over it a second time making sure you stop/start again in different spots so as not to leave any gaps.
Old 10-22-2009, 11:55 AM
keemaca's Avatar
hazard light works ...about the signal light i was just trying to be clear ..but thanks for the advice im swiitching the bulbs today..if all this fails what else might be the problem..? i just want to cover all the bases before removing everything again ...
Old 10-22-2009, 11:06 PM
fatjoe10's Avatar
when this water situation happened to me, the water traveled down the HID ignitor wire past the grommet and started flooding the ballast. I'd pull the ballast to check if there's any water in it. Usually after it shorts you will have a burning smell where the connector is. Good luck!
Japmuscle
08-03-2011 11:13 AM
blobianco
10-09-2010 10:35 AM
solomonster
03-11-2010 05:30 PM
RedhotS2k5188
07-23-2009 06:34 PM
sthestazn
08-24-2006 06:10 PM
Quick Reply: water in headlight
