replaced hub need HELP!
Old 05-15-2009, 08:18 PM
chris_barry's Avatar
Sometimes knocking it in place with a hammer is enough to allow you to torque up the nut.
Old 05-15-2009, 08:24 PM
Slows2k's Avatar
You have to hold tension on the tapered shank of the ball joint to stop it from turning, one way or another.
Old 05-16-2009, 12:47 AM
SpitfireS's Avatar
And make sure there is NO grease/dirt on the tapered parts, on the ball joint itself and in the hole of the arm.
Clean them with some brake cleaner on a rag.
The tapered parts should "grip" with some pressure.
Old 05-16-2009, 04:27 AM
Bugs2k's Avatar
prybar should get job done.
Old 05-16-2009, 08:59 AM
silvery2ks2k's Avatar
wow just a little brake cleaner on the bolts and they froze right up to tighten perfectly go figure.
WarrenW
08-11-2011 09:20 AM
Trip
04-13-2011 08:17 AM
s2kbtos
03-10-2009 01:10 PM
Pradamuimui
12-19-2004 06:42 PM
mtm584
12-19-2003 05:25 PM
Quick Reply: replaced hub need HELP!
