SRS Light Bypass AP2
Old 03-28-2009, 01:38 PM
urBan_dK's Avatar
Thumbs up SRS Light Bypass AP2
I've got a Momo hub with a 2 ohm resistor included that is supposed to prevent the SRS light from coming on.
However, it doesn't appear to be working on mine. I even did the SRS reset procedure and wasn't able to clear the light even with the resistor in place.
My question is if the AP2 SRS system is enough different that the 2 ohm resistor isn't enough? I know the AP2 has a two-stage airbag versus one stage with the AP1, but there are still only two wires going to the airbag itself.
I measured the resistance of the airbag removed from the car and it was actually only .5 ohms between the two wires. Is this my problem?
Thanks for any help/advice!
Old 03-29-2009, 02:01 PM
urBan_dK's Avatar
Bump
Old 04-15-2009, 03:14 PM
urBan_dK's Avatar
Bump.
Old 04-16-2009, 04:27 AM
AngryTurtle's Avatar
2 ohm worked fine for me. Make sure it is plugged in correctly then try the srs reset again.
Old 04-17-2009, 09:03 AM
urBan_dK's Avatar
What hub did you end up using? I'm not entirely happy with the Momo hub...
Old 04-17-2009, 09:13 AM
mikegarrison's Avatar
I wouldn't overwork this problem. A little piece of black electrical tape will solve your issue.
Old 04-17-2009, 09:47 AM
urBan_dK's Avatar
Please elaborate...are you suggesting I block the SRS light from behind the instrument panel? Is there still a code visible on the ECU or is it stored in the SRS module?
Old 04-17-2009, 10:26 AM
The works bell.
Old 04-17-2009, 10:32 AM
urBan_dK's Avatar
Originally Posted by Gigdy,Apr 17 2009, 10:26 AM
The works bell.
Did you have clearance issues with the hub where it would rub with the wiring harness attached to the cable reel? I think the Momo hob was designed with the AP1 lower profile harness in mind...
Old 04-17-2009, 10:38 AM
Not behind the panel. Just right over the light on the outside of the panel. 5-second fix to your problem.
I'm pretty sure the ECU is not tied into the SRS light in any way. My SRS light has been on for almost three years now, ever since I installed the race seats, harnesses, and roll bar.
Quick Reply: SRS Light Bypass AP2
