OEM fuel pressure regulator
Old 08-10-2008, 07:12 AM
kitkat's Avatar
Default OEM fuel pressure regulator
Any one able to send me a pic of an OEM fuel pressure regulator ? I have a comptech one on the car and need to put back the oem and i dont know what it looks like!!
Thanks
Dave
Old 08-10-2008, 07:36 AM
eSeM's Avatar
Old 08-10-2008, 07:47 AM
kitkat's Avatar
perfect ! I have just found it! thanks!
Old 08-10-2008, 08:09 AM
mikey k's Avatar
Did mine during the week and had similar problems of what went where
Old 08-10-2008, 08:24 AM
eSeM's Avatar
Why are you putting your OEM FPR on?
Old 08-10-2008, 08:37 AM
mikey k's Avatar
Upping boost, got rid of Comptech FPR and ESM
Changed to AEM EMS, RC750 injectors & 10 psi pulley
Old 08-10-2008, 08:50 AM
eSeM's Avatar
Couldn't you just adjust the Coptech FPR to the standard fuel pressure?
Old 08-10-2008, 09:04 AM
mikey k's Avatar
No it's rising rate
Plus it is a lot simpler and cleaner look with stock
Old 08-11-2008, 03:42 AM
kitkat's Avatar
Snap! Well almost" Mikey, how big is your pulley ? I have a 3.5" inch one and i think its 9psi - but im not sure!
Also did you find an easy way of taking off the original pulley without taking off the blower ?
Old 08-11-2008, 04:53 AM
mikey k's Avatar
3.628" is ~ 10 psi according to SoS chart
http://www.scienceofspeed.com/products/eng...000_SC_pulleys/
You can release the original pulley without removing the blower. But you cannot take it off - bolt will not withdraw, pulley will not clear shaft and part of the head gets in the way of the edge of hte pulley.
BTW to get the pulley off wedge a screwdriver wrapped in a cloth between the pulley and housing, then put a ring spanner on the pulley and tap it with a hammer, easy! (don't drop the woodruff key either )
Quick Reply: OEM fuel pressure regulator
