Stock oil pump flow volumes
Having problems maintaining oil pressure above 60psi with my dry sump system at high rpm. I suspect that the pump stage is undersized and cannot keep up the oil flow required once the VTEC solonoid is switched and the rpm increases (pump efficiency drops with speed). Have tried different oil grades and the scavenge side seems to be working.
Does anyone know what the oil pressure flow rate/volume is for a stock engine oil pump. Normal dry sump pumps have ratings like 18 GPM @ 4000rpm.
I was going to measure up the flow of the stock pump. Does anyone know what the speed ratio of the oil pump to crank is?
Thanks
Chris.
Thanks
Chris.
Found the information
The standard F20C pump runs at 21/34 the crank speed.
It pumps 6.5ml oil per revolution
So at 9000rpm its moving approx 36litres pre minute, approx 10 gallons/minute.
The pump is a concentric rotor style so is very efficient.
Chris.
Chris.
Dave,
Well spotted. So used to reduction ratios I got my numbers reversed.
That pump is certainly moving a truckload of oil. Probably explains why the 18 GPM pump cant maintain pressure. 95L/m is around 25 GPM
Chris.
Chris.
