S2000 Connecting Rod Lenght
HI,
Could someone help me out please, I have an S2000 engine on a
test bed, and for the tests I'm carrying out I need to know the
connecting rod lenght, the centre to centre distance, i.e. crankpin centre to piston pin centre distance.
The S2000 Manual gives the connecting rod small end
bore diameter as 22.961 mm to 22.965 mm. And the large
end bore diameter as 51.0 mm. These may help in calculating
the connecting rod lenght.
Thanks for any help
Joe
__________________________________________________ ________
Mr. Joseph Leen B.Eng M.Tech
University Of Limerick
The John Holland Research Centre
Department of Aeronautical and Mechanical Engineering (AM1083B)
Limerick
Ireland
Mobile: ++353 87 9589160
Work: ++353 61 213134
E-Mail: Joseph.Leen@ul.ie
Thanks for any help
Joe
Limerick
Ireland
As best as I can measure, 11.6 cm from the bottom of the wrist pin to the top of the main con rod beating journal. I can only guarantee accuracy to a tenth.
Hope this helps.
Hope this helps.
I embedded the above picture in AutoCad and rescalled it to known dimensions, i.e. the connecting rod small end
bore diameter and the large end bore diameter.
And I calculate the rod lenght at 152.6 mm plus or minus 1 mm.
