Tighten your throttle cable!
Old 11-11-2000, 03:29 PM
Spectre's Avatar
Just got thru changing my oil (Castrol Syntec) and noticed my throttle cable had
mucho slack! Easy to tighten, loosen
locknut (towards radiator), take up slack with adjustment nut.(towards firewall)
Play should be about 1/4" of deflection.
Kinda felt like I had better throttle response.....but then again the car as feels good after a diet of fresh synthetic oil! Tally Ho!
Old 11-11-2000, 03:38 PM
2x6spds's Avatar
Daing, Spectre, looks like you waxed your car again!!
Nice.
2x6
Old 11-11-2000, 05:49 PM
RT
RT's Avatar
Spec, make sure the over travel is not excessive at WOT. Might bend something or snap cable if too tight.
Old 11-11-2000, 06:22 PM
Prolene's Avatar
Thanks for the advice, Spectre! I checked mine and it was about 50% greater than spec. I tightened that cable and expect to see some performance gain at no cost! This should take full advantage of the tb rebore as well.
Old 11-13-2000, 09:26 AM
S2K_LA's Avatar
What is spec and how did you determine it was out of spec?
Old 11-13-2000, 09:35 AM
Prolene's Avatar
Specification calls for 4-6mm or 3/16-1/4" deflection of the cable. Mine was about 3/8". Measure by placing finger pressure on the cable midway between the set screws and tb arm until just before the tb arm starts to move. Used a ruler.
Old 11-13-2000, 02:24 PM
warpspeed's Avatar
Iwas wondering why my car was "hesitating" at take off, and after reading this post I checked my cable and there was about an inch of play!! So guys check your cables!! And thanks Spectre for the heads up!
Old 11-13-2000, 03:11 PM
Prolene's Avatar
This may be a good page to archive!
Old 11-13-2000, 03:16 PM
VaporTrail's Avatar
Agreed. I check throttle cable slack with every oil change. After about 4k miles, both mine and Sondra's had excessive slack. I tightened them up, although I noticed no difference in performance. Oh, BTW, I forgot to tell you that, Sondra. You had a LOT of slack, so, you're welcome.
Old 08-30-2011, 01:56 PM
WarrenW's Avatar
Just did mine this morning. Wow, it's like I got back some lost performance...for free!
Quick Reply: Tighten your throttle cable!
