EVS Tuning Hgh Flow Catalytic Converter
Hey guys,
Just wanted to share with you guys our new High Flow cat.
EVS Tuning High Flow Catalytic Converter (HFC) is a direct bolt-on replacement to the restrictive factory catalytic converter.
- 70mm or 63.5mm Stainless Steel tubing and flanges
- Full TIG welds
- Direct OEM Fitment with bolt on installation
- All Hardware and gaskets Included
- Built in CEL fix
-200 cel cat. Free flowing
Pricing info can be found here
https://www.s2ki.com/s2000/topic/116...tic-converter/
- Full TIG welds
- Built in CEL fix
Originally Posted by //steve\\' timestamp='1473214122' post='24056328
Which size is pictured above? If the 70mm it almost has the illusion that it's 60mm into the cat and 70mm out of it? Are the 70mm versions 70mm from the header back?
mix of both pictures. 70mm is 70mm all the way through
