Front Fender Roll without Cutting Liner
Just rolled my fenders this morning and figured I would share my plan. I read the DIY and it was suggested to trim the liner around the fender tabs. I didn't really want to do that as I like an OEM look so this is what I did.
1. Removed the top 3/4 clips that hold the liner on.
2. Rolled the fenders with the liner still over the lip of the fender. I did not move the liner out of the way.
3. When rolling was done, I tucked the liner inside of the rolled lip, then gave it a couple more passes to lock it in.
The liner sits higher up than stock, looks completely stock because I didnt cut anything, and it doesn't sag at all. Got rid of rubbing on my 17x9+63 advans with 255 RS3s.
Here are some pics:
Here are some pics:
On my passenger side I did it by removing the fender liner. Then I found this thread and thought why not try it this way as it seems like the better way to do if your rims and tires will allow it. I didn't go too aggressive but it definitely rolled it an ok amount.
