Rapid coolant leak near oil filter
Discovered a rapid coolant leak after driving a mile from cold today. This was taken from a frame of a video, you can see coolant dripping from the area circled in red.
I assume I just need to replace the heavy braided hose there? I did a search but couldn't find any threads about leaks from the oil cooler area.
http://imgur.com/haQDpgA
I thought that was the oil pressure bypass.
That is a coolant hose and yes if it's leaking you should replace that.
Bleed your system carefully after, if you are unsure here is a good thread https://www.s2ki.com/s2000/topic/106...-coolant-bleed
Confirmed - it's referred to in the service manual as the "Oil Cooler Bypass Hose" on a component location part on page 10-3. Parts sites refer to it as 19422-PCX-000 "HOSE, OIL COOLER IN", part #1 on this diagram
I've found no other reference to this part in the service manual and very little on this site. I guess it was just bad luck that mine sprang a leak, but very good luck I discovered it after only a mile into a 400 mile round trip. My car is out of commission for now but a $10 replacement from the dealer should have me back in business.
The old one looks pretty "ballooned" compared to the new. Are you going to replace the other hoses?
Thanks!
Thanks!
I considered it...I lost $40 worth of new coolant to the first one leaking, and the second hose is right next to it and also $10 from the dealer. In the end I figured it was such a rare occurrence (didn't find a single reference to this happening to anybody else) I decided against it.
I always do anytime I touch the cooling system. Call it paranoia.
Opie Oils
UK & Ireland Traders Forum
04-07-2015 01:35 AM
