Billman's TCT
Old 02-16-2016, 11:15 PM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
Default Billman's TCT
Installed Billman's TCT. Very good instructions. Easy to install. Quieted idle noise.
Removed two bolts holding down air box on the passenger side. Moving the box to the front gives you enough room to remove access plug & pull pin with straight needle nose plier.
Allen head socket on access plug.
Pin needed to be pulled to activate the TCT, seen just inside open access hole. Stamp on new TCT is visible.
Old 02-17-2016, 07:41 AM
amsfoto's Avatar
Good photos of what's probably the most "difficult" part of the install. I installed mine months ago & have had no issues. Great product!
Old 02-17-2016, 07:47 AM
Memo6453's Avatar
I know TCT can go bad as early as 20k miles, but is everyone just replacing them as a proactive change out or are you all waiting for the slightest ticking and then changing?
Old 02-17-2016, 07:59 AM
After I read all the great comments about this product on this site --- I decided to change it, even though I felt the chain noise wasn't that bad. Definitely made a difference, idle noise-wise.
Really, fairly simple fix. The biggest issue was dropping the stubby screwdriver into the engine bay. Had to jack car up and rattle a few things, to get the thing back.
alSpeed2k's Avatar
Thanks for the pics, I haven't changed mine yet, it looks fairly easy though!
Old 02-17-2016, 09:18 AM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
One of the best deals going is to get the Billman TCT at the Dragon events. Bill will install the new unit and take your old one and you will get a great price
Old 02-17-2016, 09:31 AM
cosmomiller's Avatar
Received 1,753 Likes on 1,045 Posts
I have an 09 that at about 50K miles I decided to install a Billman TCT. After a few emails back and forth from him, it was apparent that the TCT failure was a matter of "when" not "if". I had no obvious symptoms but I did a preemptive strike and changed it anyway. Never have to worry about it. The engineering of it made sense to me and the quality of what Billman shipped was first class. Would do it again.
Old 02-17-2016, 09:54 AM
jkelley's Avatar
It's pretty well known that the OEM TCT will fail eventually, for most of our cars.
The TCT install is one of the easiest things to install on the car. It takes maybe 15 minutes if you're being extremely cautious (like myself).
I replaced mine with one of Billman's GenX even though mine wasn't making any noise. I just wanted piece of mind since my car had about 85k on it at the time. 5k miles later and zero problems (of course).
Changing the oil is more a pain in the butt that installing a TCT, in my opinion. By far, actually.
Old 02-17-2016, 11:21 AM
zeroptzero's Avatar
It's a personal decision to decide when you want to do it. Honestly if yours is quiet maximize the use of it and replace it in the future when it starts giving you signals, there's no performance downside, it's just leads to bad noise. Some will last longer than others. Once it starts going south don't even consider replacing it with an OEM unit as some people have had failures quickly afterwards and the parts aren't cheap.
Old 02-17-2016, 12:35 PM
Trustd_1's Avatar
my OEM was still functioning properly, but i swapped it for Billman's GenX as preventative maintenance.
Quick Reply: Billman's TCT
