FS: Garage Sale:Poly Bushings, OEM Intake, softtop frame
FS: Garage Sale: Track Wheels, KW, Hardtop
Updated 3/31/18
New Thread here
Located in Danville PA 17821, will drive meet for big ticket items or bring anything to the NYST event.
Perfect beginner/Intermediate square track setup - $1000
(4) 17X9+62 KOSEI K5R LT GREY
-Some scratches and chips
-Minimal front fender rolling needed, depending on suspension setup
-Aluminum hub rings
(4) 255/40Z/17 HANKOOK R-S3 V2
-Used 1 season, 4-5/32 left
(2) 949 6UL 17x10+72 Bronze - $900
-No longer available from 949
-Fit under stock rear fenders
(2) Toyo R888 275/40/17
-Used one season, 2-3/32 left
I currently have 4 of these and run 275 square, which is too much for me up front. You could buy 2 new matching 17x9's from 949 and have a killer 255/275 setup. I plan to do the same if I sell these.
OEM Silverstone Hardtop - $3500
-OEM Front hardtop latches no rear OEM hardware
-Bolt on rear brackets included
-Defroster cable
-Some scratches, driver quality not show quality
Origin Carbon 3D GT Wing - 1700mm, universal mount - $800
KW V3 Coil overs about 4k miles, no issues - $1600
Also, some other stuff laying around
Energy suspension poly bushings for AP2 rear upper control arm (set of 4) - $50
-No control arm included
Energy suspension poly rear toe arm bushings pressed into factory toe arms $50
-OEM Toe arm included
OEM AP2 Softtop frame & top – $500
-Some holes in the top
Sway Bars
OEM AP1 V1 front sway bar - $75
OEM AP1 V1 rear sway bar - $75
Ankeny Racing Blade Front Sway Bar - $500
-Optional Aluminum mounts
-Custom Modified for better articulation to stop know problem of snapping end links
-Adjustable end links new last year
Custom Rear Sway bar
-NC Miata Front Hotchkis (22435F) modified to fit - $150
-3 position adjustable from softer than any OEM s2000 bar to stiffer than any OEM bar
-Good for tuning is you stiff have factory torsion diff
-Better than no rear sway bar at all
-End links not included
K&N drop in filter SOLD
OEM Intake SOLD
OEM AP1 springs/shocks SOLD
OEM Cat SOLD
OEM Header SOLD
Ground Control coilover kit SOLD
Eibach Sway-Bars set (F/R) SOLD
New Thread here
-Aluminum hub rings
-Defroster cable
Sway Bars
