Help with engine build + sheepey turbo kit
Hi guys,
I really need help with a turbo build. It's been an up hill struggle to find someone who has been there, done that and is willing to help especially in the UK, so I have taken to the forum.
I have a budget of $10-12k for parts which includes a sheepey kit with a GTX3576R running up to 600hp. I want an engine which solid but don't want to buy unnecessary/OTT parts. What I have done is put a list together from my own research.
Please could you look through and make some comments/recommendations.
Head –
OEM Valves
Supertech Steel Springs
Supertech Steel Retainers
Brian Crower Cams Stage 2
APR Head Studs
OEM head Gasket
Block [if engine lets go] –
Perhaps it would be cheaper to buy a short block with low compression pistions? https://www.inlinepro.com/s1/c-23-engine-builds.aspx
CP 10:01 87mm pistons
ACL Race bearings
Darton Dry sleeves
Brian Cower Con Rods
APR rod studs
Baffled Engine Sump
Turbo (sheepey) kit + garret –
Garret GTX3576R ball bearing turbo
Sheepey Inc - Stainless Steel Sidewinder Turbo Manifold
Sheepey Inc - 3" Stainless Steel Downpipe
Sheepey Inc - Stainless Steel dumptube
Turbosmart 45mm Wastegate
24" x 12" x 3.5" Intercooler (Garrett Core)
Aluminum Intercooler piping
Black Silicon Couplers & T-Bolt Clamps
Turbosmart Blow Off Valve
Sheepey Inc - Oil feed kit
Sheepey Inc - Oil return kit
Fuel system –
Full Blown Fuel Pumps 340's
Full Blown S2000 Fuel Surge Tank
Full Blown Fuel Rail
Full Blown Fuel Pressure Regulator
1000cc Injector Dynamics
Cooling -
Mishimoto Oil Cooler Kit
Koyo Radiator
koyo fan shroud kit
King Performance Honda S2000 Oil/Water Catch can kit [KP V2 OPTION - Aluminum finish]
- Supra Twin turbo PCV Valve breather
Electronics –
Honda Flash Pro ECU
AEM AFR gauge
AEM Boost controller
PLX oil pressure and oil temp sensors and module boxes
Science of speed RHD Pillar pod / autometer pod
Hondata 4 bar map sensor
Head –
OEM Valves
APR Head Studs
OEM head Gasket
ACL Race bearings
Darton Dry sleeves
APR rod studs
Baffled Engine Sump
Fuel system –
Cooling -
Koyo Radiator
koyo fan shroud kit
Electronics –
Honda Flash Pro ECU
AEM AFR gauge
Originally Posted by umair' timestamp='1431920280' post='23616055
A stock longblock with springs and retainers will do the trick for 600. My full turbo setup cost me 5k. Just look for good deals.
Originally Posted by guy13' timestamp='1431939407' post='23616157
[quote name='umair' timestamp='1431920280' post='23616055']
[/quote]
Thats really interesting to hear. I could just run stock until it gives in. What would be the bare minimum then in terms of parts? Wouldn't you have to lower the compression for higher boost?
I would just run the stock motor if you have a good healthy stock motor. The stock motor is great at 600whp. Also your injectors are too small if you plan on running e85. The id1000s will make 600who no problem on race gas but not on e85. I would run the id 1300 of the new fic 1650cc.
