valve cover stud/bolt stripped, pics inside
Old 01-22-2015, 02:28 PM
bcuzracecar's Avatar
Default valve cover stud/bolt stripped, pics inside
EDIT: Figured out I ordered 19 instead of 18...apparently the previous owner made the same mistake.
My "friend" snapped the head off of one of the valve cover bolts...Long story short I had to get a new bolt/"stud" for the head cover bolt to thread into.
(number 18 on the diagram)
Upon removing the old part, I noticed the threads were stripped approximately halfway up the shaft, as well as what looks like thread cuts in the non-threaded shaft of the bolt.
It required a bit of muscle to remove so I'm thinking someone went ham on it.
(old bolt removed)
I started to screw in the new piece by hand, and it felt pretty sticky. So I stopped in fear of doing more damage and created this post.
(below) New one threaded in by hand. Approximately 2cm more to go...
Old 01-23-2015, 04:31 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
You are not supposed to remove any one of those bolts unless all 20 are loosened first. By taking out just that bolt, you gouged the threads against the internal rocker shaft as it was not allowed to rotate (hence why it looked stripped)
Old 01-23-2015, 05:02 AM
bgoetz's Avatar
So I would think loosening them all and retorquing would be the right answer? Or isn't it quite that simple?
Old 01-23-2015, 05:02 PM
Utah S2K's Avatar
Not quite that easy. There is no way to tell what damage was done. This is a very critical area with extremely tight tolerances. Removing only one bolt is "out there" and may or may not have created an issue. This owner is in unknown territory as any mechanic would never do this. Engine may run fine or have a major failure at higher RPM. No way to tell.......
Utah
Old 01-23-2015, 05:47 PM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
I'd definitely replace the damaged bolts. Better hope not too much damage was done to threads in head. Pull all bolts and try to thread a new bolt (replacing the damaged one) by hand. See if it goes into the head, with the same feel, as the undamaged bolts --- goes into the undamaged head positions.
You need to get even torque onto the bolts. Prolly in a couple of stages of tightening.
That's my 2¢ worth of 2¢. Good luck!
Old 01-25-2015, 08:32 AM
N777CK T's Avatar
Oh so this isn't the way to do it and you'll be better off having the screw thread that's stuck inside removed instead?
I've just done this on mine:
And I believe in the thread below 07RioS2K is saying to do what the OP of this thread has done by buying the part the thread is stuck in and replacing that instead?
https://www.s2ki.com/s2000/topic/111...d-pics-inside/
What shall I do?
Old 01-26-2015, 01:40 PM
Utah S2K's Avatar
What shall I do?
If you can drill a small hole and get the smallest size EZ Out in it; all the power to you. But as you obviously over torqued and snapped the bolt head off it might prove problematic. Easiest would be to remove the covers, sequentially loosen the caps, replace the defective bolt and sequentially retorque.
Utah
P.S. Invest in a digital torque wrench
Old 01-26-2015, 02:08 PM
" P.S. Invest in a digital torque wrench. "
All he needs is GOOD quality torque wrench. Not necessarily a digital one. Cross-tightening pattern. In stages. I've used an old fashion Snap-On type for years. No problems.
Old 01-26-2015, 02:17 PM
N777CK T's Avatar
Ok well I've ordered part 19 and 9 on each diagram for delivery in a few days. Is it essential to loosen the others sequentially or did the OP just order the wrong part?
I used a draper torque wrench, what is a good/better one?
Valkyrie
10-13-2014 12:19 PM
Mallain123
06-19-2013 08:15 AM
mnr12
05-22-2010 06:57 AM
ahbongkadah
05-12-2008 07:42 PM
Squeezer
02-21-2003 08:35 AM
Quick Reply: valve cover stud/bolt stripped, pics inside
