Noise when driving
Old 09-19-2014, 07:42 PM
BigBang's Avatar
Default Noise when driving
SOLVED It was a loose cv axle. Thanks for the help
Hey guys, I just purchased my 2nd s2000 recently, and I just noticed a weird noise that sounds like it might be coming
from the transmission or gearbox. Its a 01 with 136k miles, never had transmission work.
This sound becomes audible ~30mph, and it louder the faster mph. The noise does not match the engine either.
Its kind of like a whine, but with more "scratchy-ness", Almost like 2 smooth metal plates are spinning against each other.
It is not coming from the rear diff, more like right under me. I looked up topics on the rear diff whine and that is not my problem.
Also looked up some gearbox bearings going out, but it not quite the same. Diff fluid is good.
Any other ideas?
Old 09-22-2014, 12:39 PM
Princeneo's Avatar
Any other ideas?
i have the same problem with my MY01, it sounds like a worn brake pads scraping metal to metal in my trans, it only happens when the car is moving,
Old 09-23-2014, 11:33 AM
chi.ted's Avatar
Have you done the axle TSB?
Old 09-24-2014, 08:09 AM
jkelley's Avatar
One of the 3 secondary shaft bearings (including the output shaft bearing) or pinion bearing, most likely.
Old 01-06-2015, 04:10 PM
559s2k's Avatar
Hey I am going through a similar problem with noises coming from the rear and the SMELL of transmission oil (not sure if this smell is only exclusive to transmission oil) in the cabin. How did you isolate and identified the problem being the cv axle and not the bearings? Thanks
polar2k
07-15-2014 08:20 PM
s2kbenztech
Tampa
09-22-2009 01:54 PM
RangOs2000
08-15-2009 05:12 AM
s2kridin
08-19-2008 08:43 PM
RazorV3
03-27-2003 07:06 AM
Quick Reply: Noise when driving
