Need hydrolock info. Billman
Long story short. Friends car sucked up water, stalled. Towed home. Removed access water, used hair dryer, removed plugs, intake, fuel pump fuse... cranked.. water shot out.. used hair dryer some more on intake mani and cylinders while plugs out. Reinstalled everything and cranked.. but it started after 2'seconds. Let it sit, it sputtered for a second until everything went back to normal with smooth idle. Only thing is, there is a different engine noise from before which scares us.
So, question is, regardless that the engine seems to run normal.. what sort of long term damage could've been done? I mean, although I could be totally wrong but doesn't water on hot metal make micro cracks. My fear is long term reliability or issues?
Bent rod or cracked piston is most common. Usually it's not the heat difference that is the issue, but the fact that water cannot be compressed plays a big role.
Because I'm not a mechanic, I don't know what to check first, to be honest with you maybe pull the oil pan and check the rods?
Received 1,720 Likes
How did it suck up water? CAI brand?
I bent a rod in my KA24 Turbo gradually over time and compression dropped. I think if you have good compression and the engine runs fine, you are good. My #4 rod gradually dropped from 170 to 150psi over the course of a month from running 25psi of boost. I thought it was rings going bag until I pulled the piston/rod and it was parabolic.
As stated, I'd change oil and call it good. It is a good idea to run higher RPM for a bit every once in a while to get oil near 212*F to cook any water off of the oil.
