Adding 3.5mm Aux input on stock head unit.
Old 06-03-2014 | 09:25 PM
Kmad86's Avatar
Default Adding 3.5mm Aux input on stock head unit.
Just wanted to make sure before I pull the trigger. All the old thread links are dead, but is this what people are using? Sure some suggest I go with a new head unit, but there's something about all stock that I like.
http://www.ebay.com/itm/Fit-For-Acco...5122c8&vxp=mtr
Old 06-04-2014 | 05:33 AM
01SSM's Avatar
I actually ordered that exact one and installed it last weekend. Super easy installation and it works perfectly.
Old 06-04-2014 | 07:44 AM
kevinS2OOO's Avatar
How do you install that?
Old 06-04-2014 | 08:46 AM
electricmarauder's Avatar
Instructions from the seller:
Installation Instruction:
1.Turn off car engine and remove key from ignition, if your radio use a security code, make sure that you have the code before unplugging the radio.
2.Unmount the radio from the dash and find CD changer port at the back of radio.
3.Plug the IPOD AUX Adapter connector to CD changer port.(For Audi/V.W/Skoda/Seat radio,connect the GND cable to the shield of the radio)
4.For IPOD/Iphone user,connector IPOD/Iphone via IPOD AUX Adapter 30P connector. Once the unit is installed just power on the car radio and ipod,you can Press CD button then you can enjoy the IPOD Music ,keep Ipod changed and ready to go.
5.For Auxiliary device such as PSP,MD.MP3.mobile etc,connect it with 3.3 Jack cable. It will start play music.
Old 06-04-2014 | 09:36 AM
takasniper's Avatar
Question would this work on 2005 s2k? Seller says 2000-04 on description
Old 06-04-2014 | 09:55 AM
Under the Description tab, it shows compatible with 00-06. I'm pretty sure 05 and 04 are the same, it should work.
Old 06-04-2014 | 10:16 AM
takasniper's Avatar
Thanks man
Old 06-04-2014 | 11:32 AM
kevinS2OOO's Avatar
Nice. Sounds like a good affordable device.
Old 06-04-2014 | 06:00 PM
thomsbrain's Avatar
I got a similar device from Crutchfield for both my S2000 and Accord and they work great. Mine have RCA inputs so I can use my own cables. For both cars, the devices can just tuck right behind the head units with no special mounting or anything. Then run the cables wherever you like!
Old 06-05-2014 | 06:17 PM
caraficionado's Avatar
This is very tempting. I currently use a FM transmitter, but it doesn't work as well as I'd like.
This looks to be the same product as the one sold through Amazon - http://www.amazon.com/iPHONE-INTEGRA...pr_product_top
I'd be all over it, but the reviews are a bit iffy though ...
Are there any other similar products or one from another manufacturer?
Quick Reply: Adding 3.5mm Aux input on stock head unit.
