Output Shaft bearings for Gearbox
Good afternoon all
After the part numbers for all associated gearbox output shaft bearings, oil seals nuts etc.
Started howling/grinding in a bit when moving in gear or out of gear, so got it up on the ramps at a mates garage and used the old screwdriver trick and sure as hell, its the output shaft bearings, the vibration/buzzing sensation through the screwdriver was mad!
Whilst we're on the subject, what's the likely cause of failure of these? oil starvation? lack of changes or too big intervals? the previous owner had it down at 99k miles and I done it around 115k miles or so and was replaced with Hondas MTF3 If I remember right.
Cheers
Tom
Cheers
Tom
Or just go to the other gearbox thread from a week or so back - all the part no.s are in that.
Part numbers should be in here
https://www.s2ki.com/...st__p__18767625
https://www.s2ki.com/...e/page__st__100
Not sure which one you are after mate but here goes...
SECONDARY SHAFT
1 21105PCY000
(21105-PCY-000) PLATE, OIL GUIDE SETTING
2 21245PX4003
(21245-PX4-003) SCREW, SEALING
3 21390PCY010
(21390-PCY-010) STAY COMP., HARNESS
4 21398PCY000
(21398-PCY-000) CLAMP, HARNESS
5 21500PCY010
(21500-PCY-010) COVER COMP., RR.
6 23230PCY010
(23230-PCY-010) SHAFT COMP., SECONDARY
7 40441PCY010
(40441-PCY-010) FLANGE, COMPANION
8 41392PCY000
(41392-PCY-000) SHIM L, 68MM (
9 41384PCY000
(41384-PCY-000) SHIM D, 68MM (0.99) £8.93 (€10.18) ($14.29) 001
10 90203PCY000
(90203-PCY-000) NUT, HEX., 27MM £6.35 (€7.24) ($10.16) 001
11 90402PL9000
(90402-PL9-000) WASHER, SPRING, 27MM £4.96 (€5.65) ($7.94) 001
12 91005PCY003
(91005-PCY-003) BEARING, BALL, 31X55X13 £23.17 (€26.41) ($37.07) 001
13 91123PCY004
(91123-PCY-004) BEARING, TAPER, 41X68X20 £46.30 (€52.78) ($74.08) 001
14 91124PCY004
(91124-PCY-004) BEARING, TAPER, 35X68X19 £46.30 (€52.78) ($74.08) 001
15 91201PCY003
(91201-PCY-003) OIL SEAL, 40X60X9 £14.72 (€16.78) ($23.55) 001
16 91301PCY003
(91301-PCY-003) O-RING, 28X2.6 £4.91 (€5.60) ($7.86) 001
17 91302PCY003
(91302-PCY-003) RING, BACK UP, 28MM £4.76 (€5.43) ($7.62) 001
18 957010804008
(957010804008) BOLT, FLANGE, 8X40 £1.26 (€1.44) ($2.02) 006
19 957010805008
(957010805008) BOLT, FLANGE, 8X50 £1.40 (€1.60) ($2.24) 002
MAIN SHAFT
1 21177PCY000
(21177-PCY-000) PIPE, OIL GUIDE £37.01 (€42.19) ($59.22) 001
2 23210PCY000
(23210-PCY-000) MAINSHAFT COMP. £530.04 (€604.25) ($848.06) 001
3 23261PCY000
(23261-PCY-000) SHAFT, REVERSE IDLE GEAR £25.34 (€28.89) ($40.54) 001
4 23262PCY000
(23262-PCY-000) HOLDER, REVERSE SHAFT £18.83 (€21.47) ($30.13) 001
5 23440PCY000
(23440-PCY-000) GEAR COMP., MAINSHAFT THIRD £284.09 (€323.86) ($454.54) 001
6 23451PCY000
(23451-PCY-000) GEAR, MAINSHAFT FOURTH £158.51 (€180.70) ($253.62) 001
7 23541PCY000
(23541-PCY-000) GEAR, REVERSE IDLE £95.10 (€108.41) ($152.16) 001
8 23546PCY000
(23546-PCY-000) WASHER, THRUST, 20X33X2 £5.04 (€5.75) ($8.06) 002
9 23581PCY000
(23581-PCY-000) GEAR, MAINSHAFT FIFTH £186.02 (€212.06) ($297.63) 001
10 23591PCY000
(23591-PCY-000) GEAR, MAINSHAFT SIXTH £186.02 (€212.06) ($297.63) 001
11 23623PCY306
(23623-PCY-306) SLEEVE SET, SYNCHRONIZER (3-4) £503.12 (€573.56) ($804.99) 001
12 23626PCY306
(23626-PCY-306) SLEEVE SET, SYNCHRONIZER (5-6) £322.88 (€368.08) ($516.61) 001
13 23917PCY000
(23917-PCY-000) COLLAR, DISTANCE, 35X42X69 £45.91 (€52.34) ($73.46) 001
14 23919PCY000
(23919-PCY-000) COLLAR, DISTANCE, 28X35X35.2 £17.22 (€19.63) ($27.55) 001
15 23927PCY000
(23927-PCY-000) WASHER, SPRING, 64MM £6.01 (€6.85) ($9.62) 001
16 90471580000
(90471-580-000) PACKING, 8MM £1.26 (€1.44) ($2.02) 001
17 91002PCY003
(91002-PCY-003) BEARING, BALL, 28X64X18 £40.54 (€46.22) ($64.86) 001
18 91003PCY003
(91003-PCY-003) BEARING, BALL, 28X82X22 £80.99 (€92.33) ($129.58) 001
19 91105PCY003
(91105-PCY-003) BEARING, NEEDLE, 42X47X30.5 £17.39 (€19.82) ($27.82) 002
20 91106PY5008
(91106-PY5-008) BEARING, NEEDLE, 20X25X26.5 £14.68 (€16.74) ($23.49) 001
21 91107PCY003
(91107-PCY-013) BEARING, NEEDLE, 35X40X35 £16.30 (€18.58) ($26.08) 001
22 91109PCY003
(91109-PCY-003) BEARING, NEEDLE, 39X44X26 £13.54 (€15.44) ($21.66) 002
23 958010806508
(958010806508) BOLT, FLANGE, 8X65 £1.26 (€1.44) ($2.02) 001
COUNTERSHAFT
1 23221PCY010
(23221-PCY-010) COUNTERSHAFT £625.04 (€712.55) ($1,000.06) 001
2 23241PCY000
(23241-PCY-000) GEAR, SECONDARY DRIVE £202.88 (€231.28) ($324.61) 001
3 23421PCY000
(23421-PCY-000) GEAR, COUNTERSHAFT LOW £158.51 (€180.70) ($253.62) 001
4 23431PCY000
(23431-PCY-000) GEAR, COUNTERSHAFT SECOND £169.12 (€192.80) ($270.59) 001
5 23521PCY000
(23521-PCY-000) GEAR, COUNTERSHAFT REVERSE £158.51 (€180.70) ($253.62) 001
6 23618PCY306
(23618-PCY-306) SLEEVE SET, SYNCHRONIZER (1-2) £524.87 (€598.35) ($839.79) 001
7 23627PCY000
(23627-PCY-000) SLEEVE SET, REVERSE HUB £126.67 (€144.40) ($202.67) 001
8 23643PG1912
(23643-PG1-912) RING, BLOCKING, 50S £82.21 (€93.72) ($131.54) 001
9 23652PB6000
(23652-PB6-000) SPRING, SYNCHRONIZER (50MM) £4.91 (€5.60) ($7.86) 001
10 23918PCY000
(23918-PCY-000) COLLAR, DISTANCE, 31X40X38X51X5 £86.11 (€98.17) ($137.78) 001
11 23925PCY000
(23925-PCY-000) WASHER, SPRING, 29MM £6.01 (€6.85) ($9.62) 001
12 90202PCY000
(90202-PCY-000) NUT, 29MM £6.35 (€7.24) ($10.16) 001
13 90203PCY000
14 90402PL9000
15 90609PC8000
(90609-PC8-000) RING, SNAP, 68MM £4.36 (€4.97) ($6.98) 001
16 91004PCY005
(91004-PCY-005) BEARING, BALL, 28X68X18 £34.70 (€39.56) ($55.52) 001
17 91102PCY003
(91102-PCY-003) BEARING, NEEDLE, 34X56X20 £52.08 (€59.37) ($83.33) 001
18 91104PCY003
(91104-PCY-003) BEARING, NEEDLE, 30X64X20 £57.88 (€65.98) ($92.61) 001
19 91104P21008
(91104-P21-008) BEARING, NEEDLE, 38X43X26 (NTN) £24.80 (€28.27) ($39.68) 001
20 91110PCY003
(91110-PCY-003) BEARING, NEEDLE, 51X57X23 £16.28 (€18.56) ($26.05) 001
21 91111PCY003
(91111-PCY-003) BEARING, NEEDLE, 44X50X28 £16.28 (€18.56) ($26.05) 001
22 91211PH8T01
(91211-PH8-T01) DAMPER, FRICTION (LOW) (KOYO) £15.28 (€17.42) ($24.45) 001
23 91212PCY003
(91212-PCY-003) DAMPER, FRICTION (LOW) £18.06 (€20.59) ($28.90) 001
SECONDARY SHAFT
1 21105PCY000
2 21245PX4003
3 21390PCY010
4 21398PCY000
5 21500PCY010
6 23230PCY010
7 40441PCY010
8 41392PCY000
9 41384PCY000
10 90203PCY000
11 90402PL9000
12 91005PCY003
13 91123PCY004
14 91124PCY004
15 91201PCY003
16 91301PCY003
17 91302PCY003
18 957010804008
19 957010805008
MAIN SHAFT
1 21177PCY000
2 23210PCY000
3 23261PCY000
4 23262PCY000
5 23440PCY000
6 23451PCY000
7 23541PCY000
8 23546PCY000
9 23581PCY000
10 23591PCY000
11 23623PCY306
12 23626PCY306
13 23917PCY000
14 23919PCY000
15 23927PCY000
16 90471580000
17 91002PCY003
18 91003PCY003
19 91105PCY003
20 91106PY5008
21 91107PCY003
22 91109PCY003
23 958010806508
COUNTERSHAFT
1 23221PCY010
2 23241PCY000
3 23421PCY000
4 23431PCY000
5 23521PCY000
6 23618PCY306
7 23627PCY000
8 23643PG1912
9 23652PB6000
10 23918PCY000
11 23925PCY000
12 90202PCY000
13 90203PCY000
14 90402PL9000
15 90609PC8000
16 91004PCY005
17 91102PCY003
18 91104PCY003
19 91104P21008
20 91110PCY003
21 91111PCY003
22 91211PH8T01
23 91212PCY003
Going to be some frantic scrolling on a phone to read that lot
thank you gentlemen!
The vibration is coming from where part no 12 is on the secondary shaft diagram.
Going to source one of them and get it fitted and hope that'll cure the issue
Cheers again!
Cheers again!
Common one that - can be changed without removing the box IIRC - worth doing some reading around. I put up with mine but the noise was and still is marginal, Pip ( Squeak ) got hers changed and it cured it completely. You can hear a metallic whirring directly under the shifter housing?
That's it, spot on.
Really annoying as I can hear it all the time, low or high speeds in gear or out.
Will get one on order tomorrow with any luck and sorted some point
Thank you all again
Thank you all again
