Forum Favourites - Tyres, Oil, Brakes, TCT etc
UK Moderator
This thread aims to summarise what the current "Forum Favourites" are for various common items. Essentially it is a simple summary of the things that lots of people are using and would recommend to others.
Note that no guarantees or formal approval/endorsement are given by S2KI.
So you would like something added to the lists, please send me a PM or post in this thread, which we'll use to get things off the ground: https://www.s2ki.com/...rum-favourites/
For loads more detail than is given here, please refer to the Technical FAQ Sticky: Technical FAQ
Mario Costa-Sa (04-01-2019)
UK Moderator
Tyres
The main Tyre Thread is here: Tyre Thread
Standard sizes are as follows:
Wheel Size....Front.......Rear
16”...........205/55 W....225/50 W
17”...........215/45 W....245/40 W
Forum Favourites at present are:
17" tyres:
Goodyear Eagle Asymmetric 2, Yokohama AD08R, Bridgestone RE002s front & S001s rear, Michelin Pilot Sport 4 Note: Bridgestone UK has reported that RE050MZ have been discontinued but some members have been able to source them from time to time.
16" tyres:
Bridgestone RE002, Toyo T1R, Yokohama AD08R (note that these are V-rated)
17" tyres:
16" tyres:
UK Moderator
Oil
The Owners' Manual specifies 10w30 for UK temperatures (-20C to +40C) or 5w40 for a wider temperature range (-30C to +40C).
10w40 and 5w30 are acceptable to use as well.
Castrol Edge 5w40 (either the red cap petrol version or the black cap diesel version or the new FST)
Fuchs Pro S Titan 5w40
Millers Nanodrive
Millers Nanodrive
ML-B (07-23-2021)
UK Moderator
Brakes
Pads
OEM Honda, Ferodo DS2500, Dixcel, [SIZE="2"]EBC Redstuff, EBC Yellowstuff, mtech, Project Mu, Carbon Lorraine [/SIZE]
Discs
OEM Honda, Bremtech, Dixcel, mtech
Fluid
Dot 4 is the recommended fluid for road use
For track use: ATE Super Blue, Motul RBF600
Callipers
OEM Honda items are very expensive, so most people replace with reconditioned items which are widely available, particularly via Ebay.
Here are the part numbers for various remanufacturers:
Rears
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Fronts
AMK:-
TCA3489 FR LH
TCA3490 FR RH
SHAFTEC;
BC8803 FR LH
BC8803R FR RH
BRAKE ENGINEERING;
CA2207 FR LH
CA2207R FR RH
Pads
Discs
Fluid
Callipers
Rears
AMK:-
RR LEFT TCA3069
RR RIGHT TCA3070
SHAFTEC:-
RR LEFT BC8896
RR RIGHT BC8896R
BRAKE ENGINEERING:-
RR LEFT CA2214
RR RIGHT CA2214R
Fronts
AMK:-
TCA3489 FR LH
TCA3490 FR RH
SHAFTEC;
BC8803 FR LH
BC8803R FR RH
BRAKE ENGINEERING;
CA2207 FR LH
CA2207R FR RH
UK Moderator
Roof
Jack R Smiths Motor Trimmers, Swansea 01792 461022
Monsoon Car Hoods http://www.s2000carhoods.co.uk/
Carhood warehouse: http://www.carhood.com/honda/
UK Moderator
Timing Chain Tensioner, also known as a TCT
The symptom of this problem is a rattle from then engine bay (sounds like a card in bicycle spokes and tends to only happen when the engine is warm).
This thread explains the problem and various fixes for it https://www.s2ki.com/s2000/topic/808...ent-or-repair/
In addition to that, a Forum Favourite is the Ballade Sports TCT http://www.balladesports.com/product...hain-tensioner
An expensive fix is to replace the Timing Chain, Sprocket, Guides and Tensioner. This is very expensive in both parts and labour. For more info, please see here: https://www.s2ki.com/s2000/topic/865...t__p__20614912
lovegroova
04-29-2021 11:48 AM
