I really need some help!
This is my first s2000, so I was bashing it around one day having fun with rwd. Dumping the clutch, sliding the car around and some launches. Well, this noise started up. It's a whirling type of noise, kind of squeaky. It appears to be coming from the front side of the transmission. I put a exedy clutch kit, using the bearing they offered. I also put a 10 pound flywheel. After I put it back together, I fired the car up. Turns out the noise is STILL there! I've done so much research trying to find the culprit but I can't find anything that relates to my problem. The noise is there whether the clutch is pressed in or out. It's not present during a cold start but once the car warms up, the noise starts up. It's funny, the noise doesn't seem to change when I drive the car although I can't hear it in higher rpms because of the exhaust. Some input would be very appreciated. Thanks guys!
Tony Torque
02-24-2011 06:26 AM
blacks2k
11-08-2001 04:00 AM
