P1412 'air control valve, voltage too low'
Old 04-07-2014, 08:18 AM
MikeArt's Avatar
Default P1412 'air control valve, voltage too low'
Hi,
I'm getting the CEL warning with the fault code: P1412 'air control valve, voltage too low'.
There are a few mentions of this code on the site but no conclusive answers. (Sometimes its mentioned as P0412)
If anyone has any troubleshooting advice that would be amazing, basically what would cause the voltage to be too low?
cheers,
Mike
Old 04-07-2014, 10:26 AM
MikeArt's Avatar
continued...
From the research it would appear a good starting point would be the secondary air pump.
Its clear its been in an accident before, there zip ties everywhere.
Fuse is okay.
Anyone got any instructions on how to check if this thing is working OK?
Cheers,
m
Old 04-10-2014, 02:54 AM
MikeArt's Avatar
Problem seems to be fixed- Pump removed, resistor fitted, CEL light has gone out.
Riknos
05-26-2014 04:33 PM
ChaseBaciles
09-26-2010 09:51 AM
lowandsmooth
02-23-2009 06:18 PM
s2kboii
05-23-2007 12:53 PM
Quick Reply: P1412 'air control valve, voltage too low'
