Noise Ident required!
I've had this for a little while, doesn't seem to be getting worse (although I've not been driving it much) and I can't see anything loose that could be causing it (e.g. heatshield).
Link
In that clip I'm accelerating from 40 to ~65. After about 6 seconds you can start to hear it, it sounds like a metallic rattle/whirr and is a fairly consistent tone/pitch.
It's only audible over 60mph, in any gear (although in 2nd/3rd the engine is louder but you can just hear it).
Happens in gear or in neutral and doesn't seem to get louder as you get faster.
It doesn't sound like a wheel bearing, and hasn't gotten any worse recently so I think that might not be it. It also doesn't appear to be coming from any particular direction. My current thinking after looking around the web is that the prop shaft cv has gone and run dry, but I've no way to diagnose this? I've checked all the bolts are tight (which they seem to be). My other thought is a bearing in the box, as that seems quite common.
Link
https://www.youtube.com/watch?v=JyHx...gdata_playeree
see my link above.
the issue I had with my accord.
started very similar to your noise then got louder and more 'metalic'
see my link above.
Sorry I can't run the link on my phone, but am I right in saying from your description that this only happens over 60mph, irrelevant of engine speed?
If you get to 60 and dip the clutch do you still get the noise?
If so, that would suggest drive train as all engine components are back to idle speed.
