rear end vibration under acceleration with brand new driveshaft shop axles.
I had no vibrations before taking my car down to change hubs and bearings in the rear but i went ahead and replaced the stock axles with some level 0 axles from drive shaft shop just to future proof the car a little bit. I am now getting a vibration only under acceleration from about 40-60 mph which seems to trail off after that. Everything that i have been looking up points to CV buckets but the axles are brand new. Im pretty sure I installed the bearings and hubs correctly; I followed the DIY on robrobinette.com to a tee with the updates from billman about how to support the bearing races and everything.
-The wheels seem to spin freely enough when up in the air so i do not think it is a hanging brake caliper.
-Tire pressures are good and the alignment is fine.
-Axles are BRAND NEW name brand units.
-Fairly certain I installed the bearings and hubs properly.
Those do not work for our car as you well know now, this has been an issue for a long time, I hope you can get a refund
I hope the vendor will take note to this issue and care about the quality and performance of the parts they sell.
well done
