Member S2000 Classifieds and For Sale Items for sale by Members. PAID MEMBERSHIP REQUIRED to post classified ads with a paid membership.
Mark this thread as Sold
PA, 17202 Garage sale of misc OEM and aftermarket stuff
Old 12-09-2013, 04:35 PM
postman's Avatar
Default PA, 17202 Garage sale of misc OEM and aftermarket stuff
Name - Ed, AKA Postman
Prices: see below
contact: PM
payment: paypal or cash
Some items are odd and I don’t even know what price to put on them. Shipping not included in prices. Prices are OBO, ridiculous lowballers will be ignored and chuckled at. Id rather not ship the large items. Pickup is always preferred. Pictures of most items. Others can be had on request. Im sure i missed some pics and items so please bare with me.
I try to describe items as best I can. some parts are super high mileage, but in proper working order. If you have a question or concern, ask before buying. Im a straight up honest guy and expect the same in return. Buy with confidence.
1.SOLD AP1 drivers headlamp. $100---- needs some work to look new again. Only hardware included are bulb clips. No broken tabs. normal stone/debris marks onlens from usage. ¾’’ bubble on bottom painted portion below low beam-normal forage. Very slight haze on inside lens from a moth that got inside(barely noticeable). If you are a do it yourselfer this lamp could look new again with minor effort.
2.SOLD Ap1 front pads---- used,no backing plates icluded. 9/32 of life left. been on shelf awile. $40
3.SOLD F20 IACV $50
4. F20 intake/vacuum hose assembly $10
5. F20 water pump housing and such. $75
6.SOLD Ap1 oem lip. $140---- what hardware if any I find I will give to you( no promises). Definetly needs some work. Stone chipped pretty good. Seal on top is no good. In pic where you see the 2 blue tape spots are cracks that run from bottom about ½ way up. Few scrapes on bottom. Still fits like oem of course. ( I was quoted $150 to have made look new again just to give you an idea).
7.ap2 soft top glass only. $30
8.stayfast cloth or OEM material soft top patches--- 2’’x5” piece. $4 SHIPPED. OR buy a larger portion for higher price.
9. Autometer carbon fiber face volts gauge. $25
10. SOLD Oem soft top tonneau cover from 2001 model. $100.--- good condition
11. f20 exhaust cam. $40 ----313k miles —
12. SOLD f20 exhaust cam. $80--- 43k miles.
13.SOLD F20 spark plug cover. $15. ---Fair condition
14. SOLD F20 vtec solenoid. $25.--- 313k miles
15.SOLD F20 vtec solenoid $70--- 43k miles
16.SOLD Ap1 front bumper. Silverstone. $40---- needs work. No broken tabs, grill is included, tow hook cover is included, emblem NOT included. Stone chipped pretty damn good and few small scrapes and a crack on very bottom edge. ( I was quoted $180 to make new again)
17. F20 oil cooler. $20. --- 313k miles
18. F20 oil cooler. $40 ---- 43k miles
19. SOLD 2 225/50/16 dunlop star spec tires.$60--- 5/32 tread left. Even wear
20. 2 205/55/16 bridgestone re760 sport tires. $90--- 8/32 tread left. Even wear
21.SOLD Ap1 front license plate assembly. $15. --- ill add new plate screws and such for free.
22. SOLD 2001 robbins stayfast soft top with glass conversion and frame/motors/rainrail assembly. Non tinted and non heated glass. NO FRONT LATCHES included $1000.--- This is off my 2001 which was installed only 3,000 miles ago. Literally looks brand new still. Since it was a glass CONVERSION it has all the appropriate installed hardware on the frame bows to work flawlessly. If you have a plastic window and need an upgrade this is the best route. Only 1 very minor issue is a few waves in material on 2[sup]nd[/sup] bow, barely noticeable, see pics. I contacted robbins after initial install and they said 2 options were to steam/iron out the waves or send back for a replacement. Id didn’t do either as I was afraid to damage the cloth with the iron technique and damn I wasn’t doing all that work over again. The issue never bothered me personally. only reason im selling is I am going the permanent hardtop route.
23. Rear plastics precut to fit a single diagonal hard dog roll bar with lower harness bar. $350--- You will get basically basically all the plastics behind the seats. fairly good job. hours worth of trimming and test fitting. save your good plastics and install these. Will also include 2 speakers which you will only be able to use 1—see pics. ( note you will have to split the roll hoop plastics to get back in and reglue them together. barely noticeable, if at all when back together.
24. F20 various rocker assembly pieces in good shape. – let me know what you need and we will make a deal.
25. SOLD Fuel rail cover. $5
26.Sold f20 cylinder head $350-- 313k miles. has valves and springs. no rocker pieces,bridges or cams/cam wheel included. head is useable as is with no issues. Personally if i were going to use it i would rebuild it simply just due to the high miles to be safe.
27. f20 crank pulley. $20 313k, normal surface rust on face. picture makes it look worse than is.
28,SOLD f20 crank pulley. $65 43k.
29 f20 timing chain cover. $80. 43k.
30.SOLD OEM hardtop front latches- $130.
31. used set of coil pack connectors/ all 4 with extra wire, no broken tabs. $25
32. AP1 front brake backing plates / have a left and right. some dents/bangs by tie rod side. still very useable. $10/each
33. Ap1 valve cover. stripped to started to sand down to polish out and lost interest. (see pic) $110
34. Ap1 crank sensor reluctor wheel. $15
35. Ap1 crankshaft chain gear. $25
36. flywheel spacer/washer and bolts $25
37. Trunk lid with OEM ap1 spoiler. silverstone, trunk is in excellent shape. The spoiler paint is a little faded with some minor scratches ( 7/10 cond.) all original paint. does not include latch or lock mechanism. PICK UP ONLY. $450
38. Radiator cooling fan and A/C condensor fan. cosmetically just ok. function fine. $75 each
39.SOLD modifry soft top elastic straps - new unused. $15 shipped
Attached Thumbnails PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131127_211047_969.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131127_211125_881.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131130_201238_296.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131130_201519_037.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_144413_170.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_145758_993.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_145838_469.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_145857_227.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_145950_982.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131208_150123_333.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131218_212429_550.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131218_212450_548.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131218_212526_052.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131218_212543_631.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20131218_212603_084.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102208_728.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102217_708.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102225_130.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102232_272.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102243_242.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102251_312.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102243_242.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102251_312.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102308_301.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102318_772.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150201_102355_628.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150332414_hdr.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150302399_hdr.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150357948.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150444170.jpg
PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150455185_hdr.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150512090.jpg   PA, 17202 Garage sale of misc OEM and aftermarket stuff-img_20150830_150831986.jpg
postman is offline
Old 12-10-2013, 08:36 AM
postman's Avatar
Up
postman is offline
postman's Avatar
Up
postman is offline
Old 12-10-2013, 09:37 AM
mndthegap1's Avatar
I was hoping to find a used flesh light in here
mndthegap1 is offline
Old 12-10-2013, 11:52 AM
shinsentuner's Avatar
I'm surprised that lip isn't already sold. GLWS!
shinsentuner is offline
Old 12-10-2013, 04:16 PM
postman's Avatar
headlamp sold, thank you
postman is offline
Old 12-11-2013, 01:04 PM
postman's Avatar
Buy this stuff to help fund track car.
postman is offline
Old 12-11-2013, 06:43 PM
postman's Avatar
more stuff and pictures added for those interested in the GENUINE OEM lip.
postman is offline
Old 12-13-2013, 02:00 PM
postman's Avatar
Up
postman is offline
Old 12-14-2013, 01:58 PM
postman's Avatar
crank pulley and some patches sold. thank you.
postman is offline
Quick Reply: PA, 17202 Garage sale of misc OEM and aftermarket stuff
